CBackup Pro 3.0.0 & Xs Minesweeper
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — CBackup Pro 3.0.0
CBackup is a reliable and easy-to-use backup solution designed specifically for Windows systems. It allows users to create secure backups of important files and folders, ensuring data protection against accidental deletion, system errors, or hardware failure.
The software supports automated backup scheduling, enabling users to run backups daily, weekly, or based on custom intervals. With incremental backup technology, CBackup only backs up changed data, improving efficiency and reducing storage usage.
Its simple interface makes it suitable for both beginners and advanced users, allowing quick setup and easy management of backup tasks.
Key Functions:
- File Backup
Back up files and folders to local drives, external disks, or network locations.
- Scheduled Backup
Automate backup tasks with daily, weekly, or custom schedules.
- Incremental Backup
Back up only modified files to save time and disk space.
- Automatic Backup Tasks
Run backups in the background without manual intervention.
- Flexible Storage Options
Supports internal drives, external HDD/SSD, USB drives, and NAS.
- Data Protection
Helps prevent data loss caused by system crashes, disk failure, or accidental deletion.
Link
Game Giveaway of the day — Xs Minesweeper
Help clear the game field by identifying safe cells and avoiding hidden traps in this logic challenge. Carefully open cells to reveal numbers indicating how many mines are located in adjacent sectors. Use the right mouse button to place flags on areas where you calculate threats to be hidden. Uncover all safe zones on the board in the shortest time possible to successfully complete the demining session. Try to avoid mistakes, as contact with any mine will lead to an immediate system failure. The gameplay requires careful analysis of numerical clues and good strategic planning.
Link
mfG
Trapped
Kein Support per PN/Mail
