Seite 1 von 1
VU+ Solo4K
Verfasst: Sa 26. Sep 2026, 19:13
von EnoSat
I wanted to update Slovak to NI, so I did a clean install, which went ok, but after booting and starting the default Pluto channel, the whole receiver crashed.
Ich wollte Slowakisch auf NI aktualisieren, also habe ich eine Neuinstallation durchgeführt, die gut lief, aber nach dem Booten und Starten des Standard-Pluto-Kanals stürzte der gesamte Receiver ab.
:sob:
VU.log
(53.88 KiB) 21-mal heruntergeladen
How can I prevent an IPTV channel from launching after installation?
Wie kann ich verhindern, dass der IPTV-Kanal nach der Installation gestartet wird?
[fe0/0] frontend fd 7 type 0
[fe0/0] add delivery system DVB-S (delivery_system: 5)
[fe0/0] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 0
[fe0/1] frontend fd 8 type 0
[fe0/1] add delivery system DVB-S (delivery_system: 5)
[fe0/1] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 1
[fe0/2] frontend fd 9 type 0
[fe0/2] add delivery system DVB-S (delivery_system: 5)
[fe0/2] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 2
[fe0/3] frontend fd 10 type 0
[fe0/3] add delivery system DVB-S (delivery_system: 5)
[fe0/3] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 3
[fe0/4] frontend fd 11 type 0
[fe0/4] add delivery system DVB-S (delivery_system: 5)
[fe0/4] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 4
[fe0/5] frontend fd 12 type 0
[fe0/5] add delivery system DVB-S (delivery_system: 5)
[fe0/5] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 5
[fe0/6] frontend fd 13 type 0
[fe0/6] add delivery system DVB-S (delivery_system: 5)
[fe0/6] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 6
[fe0/7] frontend fd 14 type 0
[fe0/7] add delivery system DVB-S (delivery_system: 5)
[fe0/7] add delivery system DVB-S2 (delivery_system: 6 / Multistream: no)
[femanager.cpp:Init:293] add fe 7
[fe0/8] frontend fd 15 type 1
[fe0/8] add delivery system DVB-C (delivery_system: 1)
[fe0/8] add delivery system DVB-C (delivery_system: 18)
[femanager.cpp:Init:293] add fe 8
[femanager.cpp:Init:314] found 9 frontends, 16 demuxes (0 busy, 0 unusable)
How do I get NIM (SSH108) into DVB-T/T2 mode ?
Wie bringe ich NIM (SSH108) in den DVB-T/T2-Modus ?
Re: VU+ Solo4K
Verfasst: Sa 26. Sep 2026, 23:14
von BPanther
EnoSat hat geschrieben: ↑Sa 26. Sep 2026, 19:13How can I prevent an IPTV channel from launching after installation?
Lösche mal / Just remove in neutrino.conf:
startchanneltv
startchanneltv_id
May work. And: Use never a streaming channel at box start.
Re: VU+ Solo4K
Verfasst: So 27. Sep 2026, 00:02
von EnoSat
The streaming channel automatically forces an installation (I don't allow the default satellite lists to be installed)
Der Streaming-Kanal erzwingt automatisch eine Installation (ich lasse nicht zu, dass die Standard-Satellitenlisten installiert werden)
In Enigma, after such an installation, an empty channel starts up with nothing on it
Nach einer solchen Installation startet im Enigma ein leerer Kanal, auf dem nichts zu sehen ist
Even after deleting
startchanneltv
startchanneltv_id
IPTV still launches
