Cables.xml für Vodafone Kabel Deutschland
Peter59
Box: VU+
Beitrag von Peter59 »
Hier mal die aktuelle cables.xml für Vodafone Kabel Deutschlnd.
Diese enthält alle genutzten Frequenzen unabhängig von der jeweiligen Kabel Ausbaustufe.
	<cable name="Vodafone Kabel Deutschland" satfeed="true" flags="9" countrycode="DEU">
		<transponder frequency="73000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="122000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="466000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="474000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="482000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="490000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="498000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="522000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="530000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="538000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="546000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="554000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="562000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="570000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="578000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="586000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="594000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="610000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		</cable>
Die vorhanden Kabel Deutschland Einträge können somit entfernt werden.
palace
Re: Cables.xml für Vodafone Kabel Deutschland
Beitrag von palace »
Hi, funktioniert die auch für das ehemalige KabelBW Gebiet?
Bei mir werden ein Haufen Sender nicht gefunden.
U.a. das gesamte ARD und ZDF Buquet.
Been thanked: 15 times
scanne mit NIT gleich EIN, dann sollte alles gefunden werden, mit jeder Liste... ;)
Has thanked: 42 times
Been thanked: 7 times
Don de Deckelwech hat geschrieben: So 21. Feb 2021, 19:47 Hi,
Funktioniert allerdings nicht mit VU+ Uno4kSE
palace
Danke, habe ich gemacht. Hilft aber nicht. Es werden nur etwa 290 Sender gefunden.
Ich weiß, dass Sender, die nicht gefunden werden, vor dem Scan funktionierten.
Z.B. „Das Erste“ oder „ZDF HD“.
Ich bin auf einer ZEE2 unterwegs.
Interessanter Weise verhielt sich das bei einem Kumpel identisch.
Nur der hat die „Chance“ genutzt, direkt auf eine Dream umzusteigen.
Gibt es hier noch einen User aus BW, der mir aktuelle Services, Bouquets und das dritte (fällt mir grad nicht ein) zur Verfügung stellen kann?
palace
mirz hat geschrieben: Di 23. Feb 2021, 01:14 ist hier nichts zu finden?
https://helpdesk.vodafonekabelforum.de/ ... egung.html
Cool, danke. Den kannte ich nicht.
palace hat geschrieben: Mo 22. Feb 2021, 20:44 Danke, habe ich gemacht. Hilft aber nicht. Es werden nur etwa 290 Sender gefunden.
Dann hat Vodafone in der Tat keine funktionierende NIT.
Peter59
Box: VU+
palace hat geschrieben: So 21. Feb 2021, 19:36 Hi, funktioniert die auch für das ehemalige KabelBW Gebiet?
Nein, die funktioniert nicht für das exUM Gebiet, nur für wie im Betreff erwähnt exKabel Deutschland.
Für das exUM Gebiet dürfte die cables.xml nutzbar sein:
<?xml version="1.0" encoding="iso-8859-1"?>
<cables>
	<cable name="Unitymedia" satfeed="true" flags="9" countrycode="DEU">
		<transponder frequency="114000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="122000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="130000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="138000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="146000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="154000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="162000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="170000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="178000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="186000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="194000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="202000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="210000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="218000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="226000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="234000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="242000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="250000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="258000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="266000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="274000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="282000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="290000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="298000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="306000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="314000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="322000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="9" modulation="5"/>
		<transponder frequency="610000" symbol_rate="6900000" fec_inner="9" modulation="3"/>
	</cable>
	</cables>
Zurück zu „Senderlisten“
