Zee in u-boot
lilo74
Box: Mutant HD51.Coolstream Trinity sat
Zee in u-boot
Beitrag von lilo74 »
Hi forum, I put online update my Zee, but reboot in u-boot? please help. :disappointed_relieved: thanks
Mutant HD51,2Coolstream Trinity Sat, Vu+solo seV2,edision argus pingulux plus,Azbox Me,golden media one,2 coolstream zee DVB-S2 and DVB-C
Re: Zee in u-boot
When your Coolstream Zee is the old version with "nevis" Hardware try this:...... :wink:
viewtopic.php?f=47&t=16#top
lilo74
Re: Zee in u-boot
Hi firend, thanks.
How long does it take to upgrade?
Re: Zee in u-boot
Flashupdate Nevis via USB-Stick: Zee, NEO2 and NEO² (NEO's with power switch) Instructions 2011
Official (Coolstreamtech) ZEE & NEO v2 Emergency Flash Instructions
Are required:
1x USB stick (FAT32 formatted)
1. On this USB stick create a directory named "coolstream"
2. In this directory coolstream copy the files below, unpacked files as kernel.img and system.img.
Both are attached as download ...
3. Switch off the switch.
4. Insert the USB stick into the USB port on the front of the device.
5. Start the device.
6. The Power LED will now light "on / off" and then "on", then press the power button on the device.
7. The control light of the USB stick should now flash, indicating that the flash operation has started.
Release the power button.
8. You need a little patience now. After the process has finished, the box will automatically restart.
9. The box should now boot again.
lilo74
Re: Zee in u-boot
Thanks firend,The process can last more than 2hrs?
I'll wait :disappointed_relieved:
Re: Zee in u-boot
lilo74 hat geschrieben: Fr 16. Jun 2017, 20:46 Thanks firend,The process can last more than 2hrs?
No...that's to long i think..... :thinking:
Are you sure that your usb Stick is right for working with the Zee..... :wink:
Is the USB stick recognized by the Zee?
lilo74
Re: Zee in u-boot
is usb kingston 16gb
lilo74
Re: Zee in u-boot
Re: Zee in u-boot
Have you the possibility to create a logfile of the boot process ?
viewtopic.php?f=14&t=7
lilo74
Re: Zee in u-boot
files in USB no work?
Re: Zee in u-boot
Try a new format of the USB stick with this tool.....
download/file.php?id=997
Open the exe file of createmini as an administrator and formate the stick.....
lilo74
Re: Zee in u-boot
friend I create a logfile? in putty.
Thanks and Regards
Re: Zee in u-boot
lilo74 hat geschrieben: Sa 17. Jun 2017, 00:42 friend I create a logfile? in putty.
Have you make a logfile?
Can you show us please....
Have you format your usb sticks with the create mini tool and tryed again...?
when you don't answer we can't help you..... :relieved:
lilo74
Re: Zee in u-boot
Thanks friend for all help, I already rebooted it I'm going to put a new picture :ok_hand:
lilo74
Re: Zee in u-boot
friend,a question To put a new image I have to rename files? o update online?
thanks
Re: Zee in u-boot
Update online is the easyest way.
lilo74
Re: Zee in u-boot
Thans Miky but online send u-boot .
Re: Zee in u-boot
lilo74 hat geschrieben: Sa 17. Jun 2017, 18:39 To put a new image I have to rename files? o update online?
@lilo74
pls put on a usb stick which is recognized by the zee the following steps:
In this way, the kernel and / or the system can be restored without a PC!
kernel:
By doing this pls make a logfile:
This logfile you have to upload here in the board with ending txt. !!!!!
Then the NI guys can see where possibly the error is !!!!
lilo74
Re: Zee in u-boot
Thanks ncsf and miky, I update online and work fine :thumbsup:
Re: Zee in u-boot
Ok guy then everything is allright..... :metal: :hand_splayed:
Wish you Much fun with the image..... :blush:
