TwinkiePaste 2.78
trapped
Been thanked: 3 times
TwinkiePaste 2.78
Beitrag von trapped »
Giveaway of the day — TwinkiePaste 2.78
TwinkiePaste is the utility for typing commonly used texts, dates, greetings, standard responses, Internet URLs, logins, passwords and code templates quickly. Versatile and unobtrusive application. If you often work with texts in foreign languages, you can select a word, then press a dedicated hotkey so as to have it translated via Google Translate. You can also select a text fragment then have it searched on the Internet without having to open a browser window beforehand. You can also customize the hotkey used by TwinkiePaste Portable, which can come in handy if the default combination is already associated to another app or you are more comfortable with using certain keys. Lightweight and useful clipboard utility that you can take with you everywhere. To wrap it up, TwinkiePaste Portable can help you save time when it comes to typing the same expression on a regular basis, especially when time is valuable.
Supported languages: English, Russian, French, German, Italian, Indonesian, Hungarian, Ukrainian, Polish, Turkish, Spanish.
Buy full license at 50% discount
Link
mfG
Trapped
Kein Support per PN/Mail
