neue WLAN Treiber zum Image mit aufnehmen
Has thanked: 130 times
Been thanked: 34 times
Re: neue WLAN Treiber zum Image mit aufnehmen
Das liegt sicher nicht am Treiber. Denn wenn man WLAN aktiviert wird trotzdem über den LAN die Verbindung hergestellt.
joker72
Box: Zee und Zee²
Beitrag von joker72 »
Ja und hier noch ein bisschen detailierter ...
[Wohnzimmer] /var/root # /sbin/wpa_supplicant -D wext -c /etc/wpa_supplicant.conf -B -i wlan0 -dd
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'wext' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
Line: 3 - start of a new network block
ssid - hexdump_ascii(len=6):
     44 61 68 6f 61 6d                                 Dahoam
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
proto: 0x3
key_mgmt: 0x2
pairwise: 0x18
group: 0x18
PSK (from passphrase) - hexdump(len=32): [REMOVED]
Priority group 0
   id=0 ssid='Dahoam'
WEXT: cfg80211-based driver detected
SIOCGIWRANGE: WE(compiled)=22 WE(source)=16 enc_capa=0xf
  capabilities: key_mgmt 0xf enc 0xf flags 0x0
ioctl[SIOCSIWAP]: Operation not permitted
WEXT: Failed to clear to disconnect
netlink: Operstate: linkmode=1, operstate=5
Own MAC address: 3c:49:37:06:3f:26
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
RSN: flushing PMKID list in the driver
Setting scan request: 0 sec 100000 usec
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Added interface wlan0
Daemonize..
Im Netz wird vermutet, dass Driver und wpa_supplicant.conf nicht zueinanderpassen ...
Gruß,
joker72
joker72
Box: Zee und Zee²
Hier noch weitere Debug Ausgaben dazu:
proto: 0x3
key_mgmt: 0x2
pairwise: 0x18
group: 0x18
Priority group 0
id=0 ssid='Dahoam'
RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
Wireless event: cmd=0x8b06 len=8
State: DISCONNECTED -> SCANNING
Starting AP scan for wildcard SSID
Scan requested (ret=0) - scan timeout 5 seconds
EAPOL: disable timer tick
Scan timeout - try to get results
Received 583 bytes of scan results (2 BSSes)
BSS: Start scan result update 1
BSS: Add new id 0 BSSID c8:0e:14:44:4f:c7 SSID 'Dahoam'
BSS: Add new id 1 BSSID ac:84:c6:b5:9f:f6 SSID 'TP-Link_9FF6'
New scan results available
Selecting BSS from priority group 0
Try to find WPA-enabled AP
0: c8:0e:14:44:4f:c9 ssid='Dahoam' wpa_ie_len=0 rsn_ie_len=20 caps=0x11
selected based on RSN IE
selected WPA AP c8:0e:14:44:4f:c7 ssid='Dahoam'
Trying to associate with c8:0e:14:44:4f:c7 (SSID='Dahoam' freq=2437 MHz)
Cancelling scan request
WPA: clearing own WPA/RSN IE
Automatic auth_alg selection: 0x1
RSN: using IEEE 802.11i/D9.0
WPA: Selected cipher suites: group 16 pairwise 16 key_mgmt 2 proto 2
WPA: clearing AP WPA IE
WPA: set AP RSN IE - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 80 00
WPA: using GTK CCMP
WPA: using PTK CCMP
WPA: using KEY_MGMT WPA-PSK
WPA: Set own WPA IE default - hexdump(len=22): 30 14 01 00 00 0f ac 04 01 00 00 0f ac 04 01 00 00 0f ac 02 00 00
No keys have been configured - skip key clearing
State: SCANNING -> ASSOCIATING
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
netlink: Operstate: linkmode=-1, operstate=5
wpa_driver_wext_associate
wpa_driver_wext_set_drop_unencrypted
wpa_driver_wext_set_psk
Setting authentication timeout: 10 sec 0 usec
EAPOL: External notification - EAP success=0
EAPOL: External notification - EAP fail=0
EAPOL: External notification - portControl=Auto
Wireless event: cmd=0x8b1a len=8
Wireless event: cmd=0x8b04 len=12
Wireless event: cmd=0x8b1a len=14
RTM_NEWLINK: operstate=0 ifi_flags=0x11003 ([UP][LOWER_UP])
RX EAPOL from c8:0e:14:44:4f:c9
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Not associated - Delay processing of received EAPOL frame
Authentication with c8:0e:14:44:4f:c9 timed out.
Added BSSID c8:0e:14:44:4f:c9 into blacklist
State: ASSOCIATING -> DISCONNECTED
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
Setting scan request: 0 sec 0 usec
Received 1078 bytes of scan results (4 BSSes)
BSS: Start scan result update 2
BSS: Add new id 2 BSSID c0:25:06:f7:30:1e SSID 'FRITZ!Box Fon WLAN 7390'
BSS: Add new id 3 BSSID 3a:43:3d:32:71:69 SSID 'Knutschkugel'
selected WPA AP c8:0e:14:44:4f:c9 ssid='Dahoam'
Trying to associate with c8:0e:14:44:4f:c9 (SSID='Dahoam' freq=2437 MHz)
WPA: using GTK CCMP
WPA: using PTK CCMP
BSSID c8:0e:14:44:4f:c9 blacklist count incremented to 2
Received 822 bytes of scan results (3 BSSes)
BSS: Start scan result update 3
skip - blacklisted
1: c0:25:06:f7:30:1e ssid='FRITZ!Box Fon WLAN 7390' wpa_ie_len=0 rsn_ie_len=20 caps=0x11
skip - SSID mismatch
2: 3a:43:3d:32:71:69 ssid='Knutschkugel' wpa_ie_len=26 rsn_ie_len=24 caps=0x11
Try to find non-WPA AP
skip - blacklisted
No APs found - clear blacklist and try again
Removed BSSID c8:0e:14:44:4f:c9 from blacklist (clear)
WPA: using GTK CCMP
WPA: using PTK CCMP
CTRL-EVENT-TERMINATING - signal 2 received
Removing interface wlan0
BSS: Remove id 1 BSSID ac:84:c6:b5:9f:f6 SSID 'TP-Link_9FF6'
BSS: Remove id 0 BSSID c8:0e:14:44:4f:c9 SSID 'Dahoam'
BSS: Remove id 2 BSSID c0:25:06:f7:30:1e SSID 'FRITZ!Box Fon WLAN 7390'
BSS: Remove id 3 BSSID 3a:43:3d:32:71:69 SSID 'Knutschkugel'
Cancelling authentication timeout
netlink: Operstate: linkmode=0, operstate=6
Gruß,
joker72
joker72 hat geschrieben: Di 28. Mai 2019, 08:06 Im Netz wird vermutet, dass Driver und wpa_supplicant.conf nicht zueinanderpassen ...
Dann nimm doch mal den Gast Zugang und teste kurz ob es ohne Verschlüsselung geht. ;)
joker72
Box: Zee und Zee²
Gorcon hat geschrieben: Di 28. Mai 2019, 19:26
Mit GAstzugang, ohne Verschlüsselung ... gleicher Fehler ...
Es liegt nicht am Passwort. Keine Chance, mich zu verbinden :-(
Gruß,
joker72
wie sieht es denn mit der IP-Adresse aus, die via DHCP kommt
und falls diese nicht via DHCP kommt: wie sieht es denn aus, wenn man mauell die Netzwerkkonfig macht ?
bei mir geht beides nicht; bekomme keine IP via DHCP und auch die manuelle Eingabe bringt keinen Erfolg
mirz hat geschrieben: Sa 1. Jun 2019, 16:02 bei mir geht beides nicht; bekomme keine IP via DHCP und auch die manuelle Eingabe bringt keinen Erfolg
Steck mal das LAN Kabel rein (bei Einstellung WLAN), ich wette dann funktioniert es. ;)
Geht es hier generell um WLAN oder um diesen hier angesprochenen neuen Treiber?
Weil ich habe 2 sticks. Einer davon mit antenne. Beide bis 150mbit.die funktionieren beide wie sie sollen.
Meine funktionieren nur wenn ich am Script etwas änder, das war früher nicht so.
joker72
Box: Zee und Zee²
fred_feuerstein hat geschrieben: So 2. Jun 2019, 13:17 Geht es hier generell um WLAN oder um diesen hier angesprochenen neuen Treiber?
Hier geht es generell nur am den neuen, angesprochenden Treiber (zumindest hab ich den Thread dafür geöffnet) ... WLAN mit alten Sticks und alten Treibern funktionieren.
Gruß,
joker72
joker72
Box: Zee und Zee²
Genauso so, sieht´s auch bei mir aus ...
Gruß,
joker72
joker72
Box: Zee und Zee²
Gorcon hat geschrieben: So 2. Jun 2019, 09:40
@Gorcon, auch das geht nicht ... es geht hier nicht um generelles WLAN, sondern nur um den besagten Treiber ...
Gruß,
joker72
Schon klar, aber wenn Du schon die WLANs "sehen" kannst, sollte der Treiber auch funktionieren. (sofern man am Script etwas ändert) Siehe: https://www.neutrino-images.de/board/vi ... 051#p17996
Leider funktioniert dann Lan nicht mehr und man muss das Script dann wieder tauschen.
joker72
Box: Zee und Zee²
Gorcon hat geschrieben: Mo 3. Jun 2019, 13:52 Schon klar, aber wenn Du schon die WLANs "sehen" kannst, sollte der Treiber auch funktionieren. (sofern man am Script etwas ändert) Siehe: https://www.neutrino-images.de/board/vi ... 051#p17996
Die beschriebenen Probleme habe ich nicht ... Meine Schlafzimmerbox läuft jetzt schon seit 4 Jahren problemlos über WLAN.
Wenn ich den alten WLAN Stick an die Wohnzimmerbox hänge, geht es auch sofort, mit der gleichen Konfiguration, halt nur nicht mit dem neuen WLAN Stick und neuen Treiber.
Gruß,
joker72
Achso, dann weiß ich auch nicht. Bei mir funktioniert kein einziger WLAN Stick mehr ohne die Anpassungen. Vorher liefen die alle problemlos.
In anderen Foren wurde von exakt den gleichen Problemen berichtet, hier aber auch.
