Telewizjada webtv script
- Has thanked: 68 times
- Been thanked: 36 times
Re: Telewizjada webtv script
...box stürzt hier zwar nicht ab!
funktioniert hier aber auch nicht ...
beim versuch einen sender zu starten kommt im log dann folgendes ...
[movieplayer.cpp:getLiveUrl:949] script: /var/tuxbox/plugins/webtv/telewizjada.lua
[movieplayer.cpp:getLiveUrl:953] script: /var/tuxbox/webtv/telewizjada.lua
[curl:download] download http://www.telewizjada.net/get_mainchannel.php => return string
[?25l
0% [> ] speed: 0.000 KB/sec
100% [=================================================>] speed: 14.712 KB/sec
[?25h
[CLuaInstance::runScript] error in script: /share/lua/5.2/json.lua:266: html passed to JSON:decode(): <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="pl" lang="pl">
<head profile="http://gmpg.org/xfn/11">
<meta name="viewport" content="width=device-width, minimum-scale=1.0, maximum-scale=1.0" />
<meta http-equiv="X-Frame-Options" content="deny">
<meta http-equiv="content-type" content="text/html; charset=UTF-8" />
<link rel="stylesheet" href="styles/layout.css" type="text/css" />
<title>Telewizjada.net</title>
<script language="JavaScript">
if(top.frames.length > 0)
top.location.href=self.location;
</script>
</head>
<body>
<!--<div id="load"></div>-->
<!-- Header -->
<div class="wrapper">
<div id="header">
<div class="fl_left"><img id="logo" src="images/logo_telewizjada.png" class="fl_left"></div>
<br class="clear" />
</div>
</div>
<!-- EU cookie policy-->
<link rel="stylesheet" type="text/css" href="js/cookiebar/jquery.cookiebar.css" />
<script type="text/javascript" src="js/cookiebar/jquery.cookiebar.js"></script>
<script type="text/javascript">
$(document).ready(function(){
$.cookieBar({
policyButton:false,
policyText:"Policy on the use of cookies",
policyURL:"policy-on-the-use-of-cookies.php",
message:"Używamy pliki cookies (tzw. ciasteczka) i inne technologie m.in. w celach prawidłowego świadczenia usług, odpowiedniego dostosowania serwisu do preferencji jego użytkowników. Korzystanie ze strony bez zmiany ustawień przeglądarki oznacza wyrażenie zgody na użycie plików cookies w pamięci urządzenia.",
acceptText:"Close"
</script><!-- / Header -->
<!-- Menu -->
<!--/ Menu -->
<!-- Body -->
<div class="wrapper col4">
<div id="main_container">
<div id="channels_container" class="rouded_corners">
<h1> Przerwa techniczna</h1>
<p> Uprzejmie informujemy, ?e obecnie trwa przerwa serwisowa zwi?zana z pracami administracyjnymi. Za utrudnienia przepraszamy.</p>
</div>
</div>
</div>
<!-- /Body -->
<!-- Footer -->
<div class="wrapper col7">
<div id="copyright">
<p style="padding-bottom:20px;">
Telewizjada.net nie zajmuje się rozprowadzaniem plików chronionych prawem autorskim. Strona nie zawiera żadnych plików, zamieszcza jedynie ich sumy kontrolne.
<br />This website does not host any files. Telewizjada.net does not distribute illegal files. Copyrighted materials and designated trademarks are property of their respective owners.
</p>
<p class="fl_left">Copyright © 2016 - All Rights Reserved - <a href="http://telewizjada.net">Telewizjada.net</a></p>
</div>
</div><!--/ Footer -->
</body>
</html>
- Has thanked: 13 times
- Been thanked: 47 times
Naja , wenn webseite in grunde down ist, woher sollten die streams kommen ?
Der segfault sollte gefixt sein.
http://git.coolstreamtech.de/?p=cst-pub ... 7ffa71e8f3
Die sind wieder online, deswegen kleine update.
- telewizjada_17052016.tar
- (20 KiB) 384-mal heruntergeladen
dasda
Hallo satbaby,
Am Besten wäre es, du würdest das Update direkt in deinen ersten Beitrag hier integrieren, bzw. die alte Datei direkt austauschen.
Neue Mitteilungen in neuen Beiträgen, die Downloads im ersten Beitrag. Wenn man den Thread schon gestartet hat, hielte ich das für das dauerhaft übersichtlichste Vorgehen.
- ncsf
- Box: Link Kabel
Bei mir geht kein einziger Sender....
Aber glaube auf der Webside tut sich auch nichts....
Google Übersetzung....Komunikat
Mając na uwadze jakość oferowanych przez nas usług zostaliśmy zmuszeni do rozpoczęcia prac nad wprowadzeniem kont premium.
Czynimy starania aby zakończyć je szybko. Za utrudnienia przepraszamy.
Aussage
In Anbetracht der Qualität der von uns angebotenen Dienstleistungen, wurden wir mit der Arbeit an der Einführung der Prämie zu starten gezwungen .
Wir sind bemüht, sie schnell zu beenden. Wir entschuldigen uns für etwaige Unannehmlichkeiten .
