- [+] Spoiler
ac3_pass=1
adzap_writeData=0
adzap_zapBackPeriod=180
adzap_zapOnActivation=0
analog_mode1=16
analog_mode2=1
analog_out=1
apply_kernel=false
apply_settings=false
audio_AnalogMode=0
audio_DolbyDigital=true
audio_volume_percent_ac3=100
audio_volume_percent_pcm=100
audiochannel_up_down_enable=false
audioplayer_cover_as_screensaver=1
audioplayer_display=0
audioplayer_enable_sc_metadata=1
audioplayer_follow=0
audioplayer_highprio=0
audioplayer_repeat_on=0
audioplayer_select_title_by_name=0
audioplayer_show_playlist=1
auto_cover=1
auto_lang=1
auto_subs=0
avsync=1
backlight_deepstandby=0
backlight_standby=0
backlight_tv=1
backup_dir=/media
bigFonts=1
bouquetlist_mode=1
cacheTXT=1
channel_mode=0
channel_mode_initial=0
channel_mode_initial_radio=0
channel_mode_radio=0
channellist_additional=1
channellist_epgtext_align_right=false
channellist_foot=1
channellist_new_zap_mode=0
channellist_numeric_adjust=1
channellist_show_channellogo=1
channellist_show_eventlogo=1
channellist_show_infobox=1
channellist_show_numbers=1
channellist_show_res_icon=1
channellist_sort_mode=0
ci_check_live=0
ci_clock_0=6
ci_ignore_messages_0=0
ci_mode=0
ci_pincode_0=
ci_rec_zapto=0
ci_save_pincode_0=0
ci_standby_reset=0
ci_tuner=-1
clock_Digit_alpha=0
clock_Digit_blue=100
clock_Digit_green=100
clock_Digit_red=100
clockrec=1
colored_events_alpha=0
colored_events_blue=0
colored_events_channellist=2
colored_events_green=70
colored_events_infobar=2
colored_events_red=95
cpufreq=0
current_volume=75
current_volume_step=1
downloadcache_dir=/media/sda1/movies
dts_pass=1
enable_sdt=1
enabled_auto_mode_0=1
enabled_auto_mode_1=1
enabled_auto_mode_10=1
enabled_auto_mode_11=1
enabled_auto_mode_12=1
enabled_auto_mode_13=1
enabled_auto_mode_14=1
enabled_auto_mode_15=1
enabled_auto_mode_16=1
enabled_auto_mode_17=1
enabled_auto_mode_18=1
enabled_auto_mode_19=1
enabled_auto_mode_2=1
enabled_auto_mode_3=1
enabled_auto_mode_4=1
enabled_auto_mode_5=1
enabled_auto_mode_6=1
enabled_auto_mode_7=1
enabled_auto_mode_8=1
enabled_auto_mode_9=1
enabled_video_mode_0=0
enabled_video_mode_1=0
enabled_video_mode_10=0
enabled_video_mode_11=0
enabled_video_mode_12=0
enabled_video_mode_13=0
enabled_video_mode_14=0
enabled_video_mode_15=0
enabled_video_mode_16=0
enabled_video_mode_17=0
enabled_video_mode_18=0
enabled_video_mode_19=0
enabled_video_mode_2=0
enabled_video_mode_3=0
enabled_video_mode_4=0
enabled_video_mode_5=1
enabled_video_mode_6=1
enabled_video_mode_7=1
enabled_video_mode_8=0
enabled_video_mode_9=0
epg_cache_time=7
epg_dir=/media/sda1/epg
epg_extendedcache_time=168
epg_max_events=30000
epg_old_events=1
epg_read=true
epg_read_frequently=0
epg_save=true
epg_save_frequently=1
epg_save_mode=1
epg_save_standby=true
epg_scan=2
epg_scan_mode=3
epg_scan_rescan=24
epg_search_history_max=10
epg_search_history_size=0
eventlist_additional=1
eventlist_epgplus=1
fan_speed=1
filebrowser_denydirectoryleave=false
filebrowser_showrights=1
filebrowser_sortmethod=1
filesystem_is_utf8=true
flashupdate_createimage_add_env=0
flashupdate_createimage_add_kernel=1
flashupdate_createimage_add_root1=0
flashupdate_createimage_add_spare=0
flashupdate_createimage_add_u_boot=0
flashupdate_createimage_add_uldr=1
flashupdate_createimage_add_var=1
font_file=/usr/share/fonts/neutrino.ttf
font_scaling_x=100
font_scaling_y=100
fontsize.button_text=14
fontsize.channel_num_zap=40
fontsize.channellist=20
fontsize.channellist_descr=20
fontsize.channellist_event=17
fontsize.channellist_number=14
fontsize.epg_date=15
fontsize.epg_info1=17
fontsize.epg_info2=17
fontsize.epg_title=25
fontsize.epgplus_item=17
fontsize.eventlist_datetime=16
fontsize.eventlist_event=17
fontsize.eventlist_itemlarge=20
fontsize.eventlist_itemsmall=14
fontsize.eventlist_title=30
fontsize.filebrowser_item=17
fontsize.general_window_text=20
fontsize.infobar_channame=30
fontsize.infobar_ecminfo=15
fontsize.infobar_info=20
fontsize.infobar_number=50
fontsize.infobar_small=14
fontsize.menu=20
fontsize.menu_foot=14
fontsize.menu_hint=16
fontsize.menu_info=16
fontsize.menu_title=30
fontsize.message_text=20
fontsize.moviebrowser_head=14
fontsize.moviebrowser_info=16
fontsize.moviebrowser_list=20
fontsize.subtitles=25
fontsize.window_radiotext_desc0=22
fontsize.window_radiotext_desc1=17
hdd_allow_set_recdir=1
hdd_format_on_mount_failed=0
hdd_fs=0
hdd_noise=254
hdd_sleep=60
hdd_statfs_mode=2
hdd_wakeup=1
hdd_wakeup_msg=1
hdmi_cec_mode=1
hdmi_cec_standby=1
hdmi_cec_view_on=1
hdmi_cec_volume=1
ifname=eth0
inetradio_autostart=0
infoClockBackground=1
infoClockFontSize=30
infoClockSeconds=1
infobar_Text_alpha=0
infobar_Text_blue=100
infobar_Text_green=100
infobar_Text_red=100
infobar_alpha=20
infobar_analogclock=1
infobar_blue=47
infobar_buttons_usertitle=true
infobar_casystem_alpha=8
infobar_casystem_blue=54
infobar_casystem_display=0
infobar_casystem_dotmatrix=0
infobar_casystem_frame=1
infobar_casystem_green=10
infobar_casystem_red=4
infobar_cn=0
infobar_gradient_body=2
infobar_gradient_body_direction=1
infobar_gradient_bottom=1
infobar_gradient_bottom_direction=1
infobar_gradient_top=1
infobar_gradient_top_direction=1
infobar_green=4
infobar_progressbar=1
infobar_red=0
infobar_sat_display=true
infobar_show=0
infobar_show_channeldesc=false
infobar_show_channellogo=2
infobar_show_dd_available=1
infobar_show_res=0
infobar_show_sysfs_hdd=1
infobar_show_tuner=1
infobar_subchan_disp_pos=4
keep_channel_numbers=1
key_bouquet_down=105
key_bouquet_up=106
key_channelList_addrecord=398
key_channelList_addremind=400
key_channelList_cancel=102
key_channelList_pagedown=109
key_channelList_pageup=104
key_channelList_sort=401
key_current_transponder=-2
key_favorites=364
key_format_mode_active=1
key_help=138
key_lastchannel=11
key_list_end=-2
key_list_start=-2
key_next43mode=407
key_pic_mode_active=1
key_pic_size_active=1
key_power_off=116
key_quickzap_down=108
key_quickzap_up=103
key_record=167
key_screenshot=417
key_standby_off_add=352
key_subchannel_down=105
key_subchannel_up=106
key_switchformat=412
key_timeshift=-2
key_tvradio_mode=-2
key_unlock=139
key_volumedown=114
key_volumeup=115
key_zaphistory=102
language=deutsch
last_webradio_dir=/var/tuxbox/webradio
last_webtv_dir=/var/tuxbox/webtv
lcd4l_brightness=7
lcd4l_brightness_standby=3
lcd4l_convert=1
lcd4l_display_type=0
lcd4l_logodir=/media/sda1/logos
lcd4l_skin=0
lcd4l_skin_radio=0
lcd4l_support=1
lcd_autodimm=0
lcd_brightness=15
lcd_contrast=15
lcd_deepbrightness=5
lcd_dim_brightness=15
lcd_dim_time=0
lcd_epgmode=0
lcd_info_line=0
lcd_inverse=0
lcd_notify_rclock=1
lcd_power=1
lcd_scroll=1
lcd_show_volume=1
lcd_standbybrightness=15
led_blink=1
led_deep_mode=3
led_rec_mode=1
led_standby_mode=3
led_tv_mode=2
livestreamResolution=1920
livestreamScriptPath=/usr/share/tuxbox/neutrino/webtv
logo_hdd_dir=/media/sda1/logos
longkeypress_duration=499
make_hd_list=1
make_new_list=1
make_removed_list=1
make_webradio_list=1
make_webtv_list=1
mbkey.copy_onefile=-2
mbkey.copy_several=-2
mbkey.cover=364
mbkey.cut=-2
mbkey.truncate=-2
menu_ButtonBar_gradient=0
menu_ButtonBar_gradient_direction=1
menu_Content_Selected_Text_alpha=0
menu_Content_Selected_Text_blue=0
menu_Content_Selected_Text_green=0
menu_Content_Selected_Text_red=0
menu_Content_Selected_alpha=8
menu_Content_Selected_blue=100
menu_Content_Selected_green=43
menu_Content_Selected_red=25
menu_Content_Text_alpha=0
menu_Content_Text_blue=100
menu_Content_Text_green=100
menu_Content_Text_red=100
menu_Content_alpha=8
menu_Content_blue=41
menu_Content_green=5
menu_Content_inactive_Text_alpha=0
menu_Content_inactive_Text_blue=85
menu_Content_inactive_Text_green=70
menu_Content_inactive_Text_red=55
menu_Content_inactive_alpha=8
menu_Content_inactive_blue=41
menu_Content_inactive_green=5
menu_Content_inactive_red=0
menu_Content_red=0
menu_Foot_Text_alpha=0
menu_Foot_Text_blue=60
menu_Foot_Text_green=60
menu_Foot_Text_red=60
menu_Foot_alpha=20
menu_Foot_blue=32
menu_Foot_green=15
menu_Foot_red=14
menu_Head_Text_alpha=0
menu_Head_Text_blue=16
menu_Head_Text_green=66
menu_Head_Text_red=87
menu_Head_alpha=0
menu_Head_blue=35
menu_Head_gradient=1
menu_Head_gradient_direction=1
menu_Head_green=6
menu_Head_red=0
menu_Hint_gradient=2
menu_Hint_gradient_direction=1
menu_Separator_gradient_enable=1
menu_SubHead_gradient=4
menu_SubHead_gradient_direction=1
menu_left_exit=0
menu_pos=0
message_frame_enable=1
minimode=0
mode_clock=0
mode_icons=0
mode_icons_background=1
mode_icons_flag0=/tmp/tuxmail.new
mode_icons_flag1=/var/etc/.call
mode_icons_flag2=/var/etc/.srv
mode_icons_flag3=/var/etc/.card
mode_icons_flag4=/var/etc/.update
mode_icons_flag5=
mode_icons_flag6=
mode_icons_flag7=
mode_icons_skin=0
mode_left_right_key_tv=1
movieplayer_bisection_jump=5
movieplayer_display_playtime=1
movieplayer_plugin=---
movieplayer_repeat_on=0
movieplayer_timeosd_while_searching=1
mpkey.audio=399
mpkey.bookmark=400
mpkey.forward=159
mpkey.goto=-2
mpkey.next_repeat_mode=-2
mpkey.pause=164
mpkey.play=164
mpkey.plugin=-2
mpkey.rewind=168
mpkey.stop=128
mpkey.subtitle=370
mpkey.time=359
network_nfs_audioplayerdir=/media/sda1/music
network_nfs_automount_0=0
network_nfs_automount_1=0
network_nfs_automount_2=0
network_nfs_automount_3=0
network_nfs_automount_4=0
network_nfs_automount_5=0
network_nfs_automount_6=0
network_nfs_automount_7=0
network_nfs_dir_0=
network_nfs_dir_1=
network_nfs_dir_2=
network_nfs_dir_3=
network_nfs_dir_4=
network_nfs_dir_5=
network_nfs_dir_6=
network_nfs_dir_7=
network_nfs_ip_0=
network_nfs_ip_1=
network_nfs_ip_2=
network_nfs_ip_3=
network_nfs_ip_4=
network_nfs_ip_5=
network_nfs_ip_6=
network_nfs_ip_7=
network_nfs_local_dir_0=/mnt/mnt0
network_nfs_local_dir_1=/mnt/mnt1
network_nfs_local_dir_2=/mnt/mnt2
network_nfs_local_dir_3=/mnt/mnt3
network_nfs_local_dir_4=/mnt/mnt4
network_nfs_local_dir_5=/mnt/mnt5
network_nfs_local_dir_6=/mnt/mnt6
network_nfs_local_dir_7=/mnt/mnt7
network_nfs_mac_0=11:22:33:44:55:66
network_nfs_mac_1=11:22:33:44:55:66
network_nfs_mac_2=11:22:33:44:55:66
network_nfs_mac_3=11:22:33:44:55:66
network_nfs_mac_4=11:22:33:44:55:66
network_nfs_mac_5=11:22:33:44:55:66
network_nfs_mac_6=11:22:33:44:55:66
network_nfs_mac_7=11:22:33:44:55:66
network_nfs_mount_options1_0=soft
network_nfs_mount_options1_1=soft
network_nfs_mount_options1_2=soft
network_nfs_mount_options1_3=soft
network_nfs_mount_options1_4=soft
network_nfs_mount_options1_5=soft
network_nfs_mount_options1_6=soft
network_nfs_mount_options1_7=soft
network_nfs_mount_options2_0=nolock
network_nfs_mount_options2_1=nolock
network_nfs_mount_options2_2=nolock
network_nfs_mount_options2_3=nolock
network_nfs_mount_options2_4=nolock
network_nfs_mount_options2_5=nolock
network_nfs_mount_options2_6=nolock
network_nfs_mount_options2_7=nolock
network_nfs_moviedir=/media/sda1/movies
network_nfs_password_0=
network_nfs_password_1=
network_nfs_password_2=
network_nfs_password_3=
network_nfs_password_4=
network_nfs_password_5=
network_nfs_password_6=
network_nfs_password_7=
network_nfs_picturedir=/media/sda1/pictures
network_nfs_recordingdir=/media/sda1/movies
network_nfs_streamripperdir=/media/sda1/music/streamripper
network_nfs_type_0=0
network_nfs_type_1=0
network_nfs_type_2=0
network_nfs_type_3=0
network_nfs_type_4=0
network_nfs_type_5=0
network_nfs_type_6=0
network_nfs_type_7=0
network_nfs_username_0=
network_nfs_username_1=
network_nfs_username_2=
network_nfs_username_3=
network_nfs_username_4=
network_nfs_username_5=
network_nfs_username_6=
network_nfs_username_7=
network_ntpatboot=false
network_ntpenable=true
network_ntprefresh=30
network_ntpserver=0.de.pool.ntp.org
omdb_api_key=20711f9e
omdb_enabled=1
osd_colorsettings_advanced_mode=false
osd_resolution=1
parentallock_defaultlocked=0
parentallock_lockage=12
parentallock_pincode=0000
parentallock_prompt=0
parentallock_zaptime=60
personalize_audio=1
personalize_blank_screen=1
personalize_bluebutton=1
personalize_bouquet_edit=1
personalize_camd_control=1
personalize_cisettings_main=1
personalize_cisettings_settings=1
personalize_daemon_control=1
personalize_drives=1
personalize_feat_key_fav=1
personalize_feat_key_rclock=4
personalize_feat_key_timerlist=2
personalize_feat_key_vtxt=3
personalize_games=0
personalize_greenbutton=1
personalize_infomenu_main=1
personalize_infomenu_service=1
personalize_keybindings=1
personalize_lua=1
personalize_media=1
personalize_media_audio=1
personalize_media_intetplay=1
personalize_media_menu=0
personalize_media_movieplayer=0
personalize_media_pviewer=1
personalize_media_upnp=1
personalize_mediaplayer=1
personalize_misc=1
personalize_mplayer_fileplay_audio=1
personalize_mplayer_fileplay_video=1
personalize_mplayer_mbrowser=1
personalize_mplayer_ytplay=1
personalize_network=1
personalize_osd=1
personalize_osdlang=1
personalize_pincode=0000
personalize_pinstatus=0
personalize_radio_mode=1
personalize_reboot=1
personalize_recording=1
personalize_redbutton=1
personalize_reload_channels=1
personalize_reload_plugins=1
personalize_reset_channels=1
personalize_restart=1
personalize_restart_tuner=1
personalize_scants=1
personalize_scripts=0
personalize_service=0
personalize_settings=0
personalize_settingsmager=0
personalize_shutdown=1
personalize_sleeptimer=1
personalize_softupdate=1
personalize_standby=1
personalize_timer=1
personalize_tools=0
personalize_tuner=1
personalize_tv_mode=1
personalize_tv_radio_mode=0
personalize_usermenu_plugin_type_games=1
personalize_usermenu_plugin_type_lua=1
personalize_usermenu_plugin_type_scripts=1
personalize_usermenu_plugin_type_tools=1
personalize_usermenu_show_cancel=1
personalize_vfd=1
personalize_video=1
personalize_yellowbutton=1
picviewer_scaling=1
picviewer_slide_time=10
plugin_hdd_dir=/media/sda1/plugins
plugins_disabled=
plugins_game=
plugins_lua=
plugins_script=
plugins_tool=
power_standby=0
pref_lang_0=German
pref_lang_1=English
pref_lang_2=French
pref_subs_0=German
pref_subs_1=English
pref_subs_2=French
progressbar_active_blue=72
progressbar_active_green=72
progressbar_active_red=72
progressbar_design=3
progressbar_design_channellist=3
progressbar_gradient=1
progressbar_passive_blue=74
progressbar_passive_green=24
progressbar_passive_red=0
progressbar_timescale_green=100
progressbar_timescale_invert=0
progressbar_timescale_red=0
progressbar_timescale_yellow=70
radiotext_enable=true
record_hours=4
recording_already_found_check=true
recording_audio_pids_default=7
recording_bufsize=4
recording_bufsize_dmx=2
recording_choose_direct_rec_dir=0
recording_epg_for_end=true
recording_epg_for_filename=true
recording_fill_warning=95
recording_save_in_channeldir=true
recording_slow_warning=true
recording_startstop_msg=true
recording_stopsectionsd=false
recording_type=3
recording_zap_on_announce=false
recordingmenu.filename_template=%C_%T_%d_%t
recordingmenu.stream_pmt_pid=false
recordingmenu.stream_subtitle_pids=true
recordingmenu.stream_vtxt_pid=true
remote_control_hardware=0
repeat_blocker=450
repeat_genericblocker=100
rounded_corners=0
scrambled_message=true
screen_EndX_crt_0=1199
screen_EndX_crt_1=1839
screen_EndX_lcd_0=1234
screen_EndX_lcd_1=1869
screen_EndY_crt_0=534
screen_EndY_crt_1=824
screen_EndY_lcd_0=689
screen_EndY_lcd_1=1034
screen_StartX_crt_0=80
screen_StartX_crt_1=80
screen_StartX_lcd_0=45
screen_StartX_lcd_1=50
screen_StartY_crt_0=45
screen_StartY_crt_1=45
screen_StartY_lcd_0=30
screen_StartY_lcd_1=45
screen_preset=1
screensaver_delay=1
screensaver_dir=/usr/share/tuxbox/neutrino/icons/screensaver
screensaver_mode=1
screensaver_mode_text=0
screensaver_random=0
screensaver_timeout=10
screenshot_count=1
screenshot_cover=1
screenshot_dir=/media/sda1/movies
screenshot_format=1
screenshot_mode=0
screenshot_scale=1
screenshot_video=1
shadow_alpha=0
shadow_blue=8
shadow_green=8
shadow_red=8
shoutcast_dev_id=fa1669MuiRPorUBw
shoutcast_enabled=1
show_ecm=0
show_ecm_pos=0
show_empty_favorites=1
show_menu_hints=true
show_menu_hints_line=true
show_mute_icon=1
shutdown_count=2
shutdown_min=180
shutdown_real=false
shutdown_real_rcdelay=false
shutdown_timer_record_type=false
sleeptimer_min=0
sms_channel=0
sms_movie=1
softupdate_autocheck=false
softupdate_mode=1
softupdate_name_mode_apply=0
softupdate_name_mode_backup=0
softupdate_proxypassword=
softupdate_proxyserver=
softupdate_proxyusername=
softupdate_url_file=/var/etc/update.urls
spectrum=false
srs_algo=1
srs_enable=0
srs_nmgr_enable=0
srs_ref_volume=75
standby_cpufreq=50
start_volume=100
startchannelradio=ROCK ANTENNE
startchannelradio_id=-4715268779783421792
startchanneltv=Das Erste HD
startchanneltv_id=-5451602972360234947
subs_charset=CP1252
theme_name=Neutrino-3.0
timer_followscreenings=1
timer_remotebox_ip_count=0
timeshift_auto=0
timeshift_delete=1
timeshift_hours=4
timeshift_pause=1
timeshift_temp=1
timeshiftdir=
timezone=(GMT+01:00) Amsterdam, Berlin, Bern, Rome, Vienna
timing.chanlist=180
timing.epg=180
timing.filebrowser=180
timing.infobar_media_audio=0
timing.infobar_media_video=6
timing.infobar_radio=0
timing.infobar_tv=6
timing.menu=180
timing.numericzap=3
timing.popup_messages=6
timing.static_messages=180
timing.volumebar=3
tmdb_api_key=7270f1b571c4ecbb5b204ddb7f8939b1
tmdb_enabled=1
ttx_font_file=/usr/share/fonts/tuxtxt.ttf
update_dir=/tmp
update_dir_opkg=/tmp
uselastchannel=0
usermenu_key_4=164
usermenu_key_5=392
usermenu_key_6=-2
usermenu_key_blue=401
usermenu_key_green=399
usermenu_key_red=398
usermenu_key_yellow=400
usermenu_tv_4=9
usermenu_tv_4_text=
usermenu_tv_5=6
usermenu_tv_5_text=
usermenu_tv_blue=27,28,21,20,1,39,10,11,24,19,14
usermenu_tv_blue_text=Erweiterungen
usermenu_tv_green=6
usermenu_tv_green_text=Tonwahl
usermenu_tv_red=2,3,4,13,1,23,22
usermenu_tv_red_text=EPG
usermenu_tv_yellow=7,35
usermenu_tv_yellow_text=Bildoptionen
vcr_AutoSwitch=true
version_pseudo=20170711000000
video_43mode=1
video_Format=3
video_Mode=12
video_dbdr=0
video_psi_brightness=128
video_psi_contrast=128
video_psi_saturation=128
video_psi_step=2
video_psi_tint=128
volume_digits=true
volume_pos=5
volume_size=26
weather_api_key=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
weather_city=Berlin
weather_country=0
weather_enabled=0
weather_location=52.52,13.40
webradio_xml=/var/tuxbox/webradio/webradio_usr.xml
webradio_xml_auto=1
webradio_xml_count=0
webtv_xml=/var/tuxbox/webtv/webtv_usr.xml
webtv_xml_auto=1
webtv_xml_count=0
widget_fade=false
window_height=100
window_size=100
window_width=100
xmltv_xml_count=0
youtube_dev_id=AIzaSyBLdZe7M3rpNMZqSj-3IEvjbb2hATWJIdM
youtube_enabled=1
zap_cycle=1
zappingmode=0
zapto_pre_time=0
Satellitenauswahl bzw Aufnahme-Probleme aus dem Deep-Standby
Lars.Berlin
- Has thanked: 17 times
- Been thanked: 9 times
Re: Satellitenauswahl bzw Aufnahme-Probleme aus dem Deep-Standby
Meine neutrino.conf;
Zuletzt geändert von Lars.Berlin am Di 29. Dez 2020, 21:10, insgesamt 1-mal geändert.
Greetz Larsi
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
Lars.Berlin
@Don,Don de Deckelwech hat geschrieben: ↑Di 29. Dez 2020, 12:48 edit: hier viereinhalb Beiträge abzutrennen für einen neuen Thread finde ich unnötig, ich hab aber den Threadtitel erweitert
danke.
Das mit der nicht funzenden Timeraufnahme, kam mir ja auch erst etwas später ein.
Greetz Larsi
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
Thomas
die Datei sieht aus wie von anderen Receiver übernommen, da stehen sachen drin die bei arm nicht da sind
es wäre sinnvoll eine Saubere nochmal zu verwenden
leider hab ich nicht gefunden, ob Receiver bei aufnahme versuch aufwacht oder ob der komplett aus bleibt
Lars.Berlin
Was heisst "Saubere" ?Thomas hat geschrieben: ↑Di 29. Dez 2020, 22:27die Datei sieht aus wie von anderen Receiver übernommen, da stehen sachen drin die bei arm nicht da sind
Verstehe ich nicht.
Habe sie so komplett aus einer meiner HD51 heraus kopiert und 1:1 hier rein kopiert und gepostet.
Es ist auch eine normales V3.99 NI-Image aus der Online-Datenbank hier vom Board.
Greetz Larsi
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
Thomas
hast du die einstellung übernommen mal aus sicherung irgendwann was zurückgespielt, so sieht das zumindest aus
ich würde die löschen, strom klauen dann fährt er auch und einrichtungsassi müsste kommen
Lars.Berlin
Nein, ich habe keine Einstellungen übernommen.
Wo soll ich Strom klauen?
Wohin soll er fahren?
Der Einrichtungsassistent, erscheint doch nur bei der Erstinstallation.
Du schreibst sehr wirr.
Für mich nicht zu verstehen.
Greetz Larsi
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
- Been thanked: 6 times
Na nicht wirklich. Wird der Receiver nur neu gestartet, wird die conf zurück geschrieben. Deswegen muss der Receiver vom Strom genommen werden.
Für Lars.Berlin: Stecker raus und dann wieder rein.
Lars.Berlin
Aja, dass leuchtet ein.
Werde ich am Nachmittag mal testen und dann hier die "neue" Conf posten.
Greetz Larsi
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
- sammy909
- Box: Tank
- Has thanked: 5 times
- Been thanked: 8 times
Ich dachte Neustarten reicht, hab das bei ein paar Boxen gemacht, die nicht mehr funktioniert haben, aber noch per ftp zu erreichen waren.
Paul Pang Jplay Fidelizer
ohne es testen zu wollen hätte ich gedacht, dass ein Werksreset in den Einstellungen ebenfalls reicht.
Zumindest bei den HD2-Boxen mit var_init ist dem so, denn da wird der Inhalt von var_init nach var kopiert und wenn man da eine funktionierende Konfiguration abgelegt hat und ab und an die Senderliste aktualisiert, dann ist alles wieder so wie beim Anlegen = tolle Funktion, hat mir bei mehreren Bekannten, denen ich so eine Kiste verkauft habe und die es dann doch irgendwann schaffen die Box zu verkonfigurieren, immer gut geholfen, die Box nicht nur zu zurückzusetzen, womit kein Laie was anfangen kann, sondern wieder auf einen funktionierenden Stand zurück zu stellen. Ich finde es sehr schade, dass trotz mehr als ausreichend Speicherplatz, dieses Feature in der HD51 nicht zur Anwendung kommt
- Has thanked: 130 times
- Been thanked: 34 times
Nein, braucht man nicht die Box wacht auch mit dem Aufnahmetimer aus dem DS auf. Mache ich schon seit der D-Box2 nur so.
Voraussetzung ist aber das man immer beim Aufwachen einen Sender nutzt der auch eine gültige Urzeit liefert, ansonsten muss man ntp nutzen.
Lars.Berlin
Ich habe bei allen meinen Receivern seit NI- und HD1/HD2-Zeiten immer "Das Erste HD", als Startkanal gesetzt.Gorcon hat geschrieben: ↑Do 31. Dez 2020, 14:21Nein, braucht man nicht die Box wacht auch mit dem Aufnahmetimer aus dem DS auf. Mache ich schon seit der D-Box2 nur so.
Bei einer programmierten Timeraufnahme als Bsp. "Sky One HD", sollte doch die Box nach dem Aufwachen aus dem DS gleich zu diesem Sender schalten!?
Dies jedenfalls, taten alle meine Coolis, welche ich vorab besaß.
Greetz Larsi
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
4x HD51, Satellit
2x HD51, Kabel
6x HD60, Satellit
Bei meiner hd51 geht es nur wenn ich den Umschalt-Timer setze
- Has thanked: 16 times
- Been thanked: 35 times
Nein im Ernst, theoretisch könnte es ja sein, dass ein Umschalttimer anders behandelt wird, als ein Aufnahmetimer.
Das glaube ich aber nicht, denn schlussendlich wird ja während des Abschaltens nur eine Art Countdown zur Hardware geschickt (wann sie wieder aufwachen soll), eine richtige Uhr gibt es ja nicht.
Aber wie auch immer, die Auswertung, was nach dem Aufwachen geschehen soll, Aufnahme oder Umschalten, passiert ja später in Software, das Aufwachen ansich muss also in beiden Fällen funktionieren.
Ich lasse mich da aber gern eines besseren belehren, womöglich testet Lars das ja mal und kann berichten.
Findet den Fehler. Vllt wenn du mal mehr als einen Satz...?
Nicht sofort, erst kurz vor der Aufnahme. Man muss bei einem Test die Box auch ca. 5min vor dem Ereignis (bei Aufname +Vorlaufzeit) heruntergefahren haben, sonst wacht sie nicht auf.Lars.Berlin hat geschrieben: ↑Do 31. Dez 2020, 15:08
Bei mir haben die Aufnahmen aus dem DS mehrfach nicht geklappt.Don de Deckelwech hat geschrieben: ↑Do 31. Dez 2020, 20:35 Hi,Findet den Fehler. Vllt wenn du mal mehr als einen Satz...?
Habe dann einen Freund gefragt und der gab mir den Tipp es so zu machen:
EPG-Plus/ gewünschte Sendung auswählen/ Taste Info drücken/ über Taste gelb das Umschalten setzen ( bei mir ist das Umschalten 6min vor Aufnahmestart-Korrektur gesetzt )/ über Taste rot die Aufnahme setzen
Seid dem ich so vorgehe klappen alle Aufnahmen aus dem DS
Ist aber nicht normal. Entweder klappt jede Aufnahme oder keine. Mit den Aktuellen Images geht das auf jedenfall. Ursachen könnten veraltete Settings (von uralten Updates) sein.
Ich würde das sonst mal testen und dabei ein Log machen wenn die Box hochfährt und nichts aufnimmt. Denn hochfahren sollte sie in jedem Fall(sonst würde auch der Umschalttimer nicht funktionieren)
Wozu Log und forschen?
Vielleicht umständlich, aber funktioniert
