HD51 UHD HDR Sender schmieren ab
HossaWurst
Beitrag von HossaWurst »
Ich aber ein Probnlem mit der HD51 und aktuellen 4.xx Image von heute, hier schmiert UHD1(Free Mode) und alle anderen UHD Sender nach einer paar Sekunden ab. UHD QVC 1 & 2 geht komischerweise.
Gruß HossaWurst
Anbei Logfile:
UHD1 by ASTRA > Bild wird schwarz nach ein paar Sekunden
**************************** CChannelList::zapToChannel me 0xa95030 Alle Kanäle tuned 822 new UHD1 by ASTRA / HD+ -> ac84040b00010002
StopAutoRecord: autoshift 0
2021-06-23 19:23:57.406 [sectionsd] commandserviceStopped
2021-06-23 19:23:57.406 [sectionsd] cnThread: stop eit update filter (active)
stopPlayBack: stopping...
stopPlayBack: stopped
CChannelList::adjustToChannelID me 0xa95030 [Alle Kanäle] list size 2999 channel_id ac84040b00010002
2021-06-23 19:23:57.407 [sectionsd] commandserviceStopped done
CNeutrinoApp::showChannelList: nNewChannel -2
ShowText 'ZDF HD'
[zapit.cpp:ZapIt:518] [zapit] zap to UHD1 by ASTRA / HD+ (ac84040b00010002 tp 2af100c0040b0001)
[zapit] saving channel, apid 17ea sub pid 0 mode 0 volume 75
[zapit] GetConfig...
[femanager.cpp:allocateFE:751] pip demux: 3
[zapit.cpp:StopPlayBack:2394] standby 0 playing 1 forced 0 send_pmt 1
[capmt.cpp:SetMode:309] channel b24403f300012b66 [ZDF HD] mode 0 STOP src 0 mask 1 -> 0 update 0 rmode 0 mp 0
[capmt.cpp:SetMode:385]  (newmask == 0)
[ca_ci] -> SendCAPMT
TP: B24403F30001
SID: 2B66
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 0
Mode: 0
Enabled: STOP
[ca_ci] -> GetNumberCISlots
CI: CAM not found
[dvb-sub] paused
[fe0/0] Diseqc cmd: 0xE0 0x10 0x38 0xF2
[fe0/0] tune to 10993000 DVB-S2 8PSK 5/6 H/L srate 21996000 pli -1 plc 0 plm 1 (tuner 1243000 offset 9750000 timeout 4000)
[frontend.cpp:setFrontend:1542] [fe0/0] tuner pilot 2 (feparams 2)
[frontend.cpp:getEvent:804] [fe0/0] ******** FE_HAS_LOCK: freq 1243000
[fe0/0] tuning took: 267 msec (min 267 max 476)
CRemoteControl::handleMsg: EVT_TUNE_COMPLETE (ac84040b00010002)
2021-06-23 19:23:58.009 [sectionsd] commandserviceChanged: Service change to ac84040b00010002 demux #0
2021-06-23 19:23:58.010 [sectionsd] cnThread: stop eit update filter (not active)
2021-06-23 19:23:58.012 [sectionsd] timeThread: get DVB time ch 0x040b00010002 (isOpen 1)
[zapit] parsing pmt pid 0x60 (UHD1 by ASTRA / HD+)
2021-06-23 19:23:58.108 [sectionsd] timeThread: get DVB time ch 0x040b00010002 rc: 29 neutrino_sets_time 0
2021-06-23 19:23:58.109 [sectionsd] SIsectionTIME::parse: TOT time: Wed Jun 23 19:23:57 2021
2021-06-23 19:23:58.109 [sectionsd] timeThread: timediff -1109240, current: 23.06.2021 19:23:58, dvb: Wed Jun 23 19:23:57 2021
2021-06-23 19:23:58.109 [sectionsd] difference is < 120s, using adjtime(-1, -109240). oldd(0, -280438)
2021-06-23 19:23:58.109 [sectionsd] timeThread: Time set via DVB (TOT), going to sleep for 1800 seconds.
[zapit] channel found, audio pid 66, subtitle pid 0 mode 0 volume 75
[zapit.cpp:StartPlayBack:2310] standby 0 playing 0 forced 0
[zapit] vpid 65 apid 66 pcr 65
[HAL: 0062c2e8:audio ] SetStreamType 1 (0x1)
[capmt.cpp:SetMode:309] channel ac84040b00010002 [UHD1 by ASTRA / HD+] mode 0 START src 0 mask 0 -> 1 update 0 rmode 0 mp 0
[capmt.cpp:SetMode:337]  socket only
[capmt.cpp:SetMode:483]  (oldmask != newmask) || force_update)
TP: AC84040B0001
SID: 0002
SOURCE: 0
CA_MASK: 1
CALEN: 30
Scrambled: 0
Mode: 0
Enabled: START
[ca_ci] -> FindFreeSlot
No free ci-slot
CaMap Empty
[pmt] set update filter, sid 0x2 pid 0x60 version 13
2021-06-23 19:23:58.287 [sectionsd] addEvent: ch 040b00010002 running 0 (next) got_CN 0
TuxTxt stopped service 17f2
TuxTXT pid: 0
ShowText 'UHD1 by ASTRA / HD+'
2021-06-23 19:23:59.341 [sectionsd] addEvent: ch 040b00010002 running 4 (curr) got_CN 2
2021-06-23 19:23:59.868 [sectionsd] cnThread: eit update filter, ch 0x040b00010002, current ver 0x14  got events 3 (not active)
[sdt monitor] wakeup...
[SDT] section 0 last 0 tsid 0x40b onid 0x1 -> use
[SDT] tid 40b onid 01
[pat] sid 183a not found
[sdt monitor] no changes.
key: 0002 value 1, translate: 0002 -1-
ShowText '1---'
CI: CAM not found
key: 0002 value 0, translate: 0002 -1-
[b][size=150]QVC UHD > läuft[/size][/b]
**************************** CChannelList::zapToChannel me 0xa95030 Alle Kanäle tuned 975 new QVC UHD -> b12003ee00011086
2021-06-23 19:27:51.586 [sectionsd] commandserviceStopped
2021-06-23 19:27:51.586 [sectionsd] cnThread: stop eit update filter (active)
2021-06-23 19:27:51.586 [sectionsd] commandserviceStopped done
CChannelList::adjustToChannelID me 0xa95030 [Alle Kanäle] list size 2999 channel_id b12003ee00011086
ShowText 'Das Erste HD'
[zapit.cpp:ZapIt:518] [zapit] zap to QVC UHD (b12003ee00011086 tp 2c1800c003ee0001)
[zapit] saving channel, apid 13f2 sub pid 0 mode 0 volume 75
[capmt.cpp:SetMode:309] channel b45403fb0001283d [Das Erste HD] mode 0 STOP src 0 mask 1 -> 0 update 0 rmode 0 mp 0
TP: B45403FB0001
SID: 283D
SOURCE: 0
CA_MASK: 0
CALEN: 0
Scrambled: 0
Mode: 0
Enabled: STOP
[dvb-sub] paused
CI: CAM not found
[fe0/0] Diseqc cmd: 0xE0 0x10 0x38 0xF0
[fe0/0] tune to 11288000 DVB-S2 8PSK 2/3 V/R srate 22000000 pli -1 plc 0 plm 1 (tuner 1538000 offset 9750000 timeout 4000)
[frontend.cpp:getEvent:804] [fe0/0] ******** FE_HAS_LOCK: freq 1538000
[fe0/0] tuning took: 216 msec (min 216 max 476)
CRemoteControl::handleMsg: EVT_TUNE_COMPLETE (b12003ee00011086)
2021-06-23 19:27:52.223 [sectionsd] commandserviceChanged: Service change to b12003ee00011086 demux #0
2021-06-23 19:27:52.224 [sectionsd] cnThread: stop eit update filter (not active)
2021-06-23 19:27:52.225 [sectionsd] timeThread: get DVB time ch 0x03ee00011086 (isOpen 1)
[zapit] parsing pmt pid 0x60 (QVC UHD)
2021-06-23 19:27:52.693 [sectionsd] timeThread: get DVB time ch 0x03ee00011086 rc: 74 neutrino_sets_time 0
2021-06-23 19:27:52.693 [sectionsd] SIsectionTIME::parse: TOT time: Wed Jun 23 19:27:53 2021
2021-06-23 19:27:52.693 [sectionsd] timeThread: timediff 306078, current: 23.06.2021 19:27:52, dvb: Wed Jun 23 19:27:53 2021
2021-06-23 19:27:52.693 [sectionsd] difference is < 120s, using adjtime(0, 306078). oldd(0, -19789)
2021-06-23 19:27:52.693 [sectionsd] timeThread: Time set via DVB (TOT), going to sleep for 1800 seconds.
[zapit] channel found, audio pid 100, subtitle pid 0 mode 0 volume 75
[zapit] vpid FF apid 100 pcr FF
[capmt.cpp:SetMode:309] channel b12003ee00011086 [QVC UHD] mode 0 START src 0 mask 0 -> 1 update 0 rmode 0 mp 0
TP: B12003EE0001
SID: 1086
SOURCE: 0
CA_MASK: 1
CALEN: 30
Scrambled: 0
Mode: 0
Enabled: START
No free ci-slot
CaMap Empty
[pmt] set update filter, sid 0x1086 pid 0x60 version 2
TuxTxt stopped service 13f0
TuxTXT pid: 39
TuxTxt: source demux 0
TuxTxt service started 39
TuxTxt running thread...(0039) nice error
ShowText 'QVC UHD'
2021-06-23 19:27:53.524 [sectionsd] addEvent: ch 03ee00011086 running 4 (curr) got_CN 0
2021-06-23 19:27:53.583 [sectionsd] addEvent: ch 03ee00011086 running 1 (next) got_CN 1
2021-06-23 19:27:57.523 [sectionsd] cnThread: eit update filter, ch 0x03ee00011086, current ver 0x0d  got events 3 (not active)
[SDT] section 0 last 0 tsid 0x3ee onid 0x1 -> use
[SDT] tid 3ee onid 01
CServiceManager::CopyCurrentServices: [RAI News 24] remove
CServiceManager::CopyCurrentServices: [Deutschland Vozrozhdenie] remove
[sdt monitor] found changes.
CI: CAM not found
key: 0003 value 1, translate: 0003 -2-
ShowText '2---'
CI: CAM not found
key: 0003 value 0, translate: 0003 -2-
ShowText 'QVC UHD'
//edit vanhofen: Codeblock hinzugefügt
Zuletzt geändert von HossaWurst am Do 24. Jun 2021, 10:03, insgesamt 1-mal geändert.
Been thanked: 14 times
Re: HD51 UHD Sender schmieren ab
UHD1 läuft hier auf HD51 und HD61 einwandfrei im FTA Modus.
Image ist vom 15.06.2021
Sag mal
die anderen UHD Sender auf 19.2E
deinen Imagestand
Empfangsverhältnisse ein oder zwei Tuner wie konfiguriert ?
EPGScan im Hintergrund ?
Ci und oder Softcam aus ?
das hier in deinem Log sagt mir, das da was im Hintergrund passiert:
HossaWurst
Moin @All,
der Fehler hängt mit HDR zusammen, mein Samsung Q70-Series schaltet zwischen beiden Modi ständig hin und her und macht somit kein Bild. QVC hat kein HDR und funktioniert.
Das alte Image 3.5 aus 2018 macht HDR und alles Sender sind hell.
Gibt es bei den neuen Images noch eine Einstellmöglichkeit, wann wurde zuletzt beim der HD51 und HDR was geändert?
Sag mal
deinen Imagestand
Hat alles nix gebracht, hat ja auch nix mit HDR zu tun :)
Aber Danke für die Hilfe.
HossaWurst
Been thanked: 9 times
Re: HD51 UHD HDR Sender schmieren ab
Bei der HD51 muss man sich entscheiden, entweder PiP (Boxmode 12) oder HDR (Boxmode 1) - beides zusammen geht nicht.
Zuletzt geändert von TangoCash am Do 24. Jun 2021, 14:13, insgesamt 1-mal geändert.
HossaWurst
Das ist doch mal eine gute Antwort!
DANKE
HossaWurst
Guitarrero
Beitrag von Guitarrero »
Mal dumm nachgefragt, kann man nicht irgendwie verhindern, dass auf HDR gewechselt wird? Erst wird ja das normale UHD Signal gezeigt und das klappt auch gut. Bei der Umschaltung auf HDR erst fängt das Problem an. Wenn ich nun auf Boxmode12 bin und keinen Wert auf das HDR lege würde es ja reichen, den HDR Modus zu verhindern. Würde so etwas machbar sein?
Hab grade keine box zur hand, aber mal testen per console:
echo bt709 >/proc/stb/video/hdmi_colorimetry
Guitarrero
Hi Tango,
solltest du mich gemeint haben, habe deine Zeile via Putty eingegeben und dann mal auf einem HDR Sender geschalten. Ist unverändert.
Zurück zu „Entwicklung“
