WebGrabPlus
lilo74
Box: Mutant HD51.Coolstream Trinity sat
WebGrabPlus
Beitrag von lilo74 »
Hi All Forum,my question is, can it be run on Neutrino as well as epgimport on E2, WebGrab?
Thanks and Regards
Mutant HD51,2Coolstream Trinity Sat, Vu+solo seV2,edision argus pingulux plus,Azbox Me,golden media one,2 coolstream zee DVB-S2 and DVB-C
Been thanked: 16 times
Re: WebGrabPlus
Webgrab itself cannot run on setopbox, or really badly ;) but the epg can be imported, but u have to map the epg channels, as in e2
lilo74
Re: WebGrabPlus
Hi Tango, and can you give me a brief explanation of how to do?
Regards :thumbsup:
Has thanked: 17 times
Been thanked: 17 times
Re: WebGrabPlus
/var/tuxbox/config/epgmap.xml
Beispiel:
	<filter channel_id="ffffffff8b478c00" >5c5c3b948002db3c3e0b262e</filter> --Pluto TV Movies
Has thanked: 42 times
Been thanked: 147 times
Re: WebGrabPlus
muss das nicht heissen
/var/tuxbox/config/zapit/epgmap.xml
lilo74
Re: WebGrabPlus
Thanks all for responding quickly,I have more doubts, annie in your example
Said this:
<filter channel_id="ffffffff8b478c00">5c5c3b948002db3c3e0b262e</filter> --Pluto TV Movies
ok ,this What is it >5c5c3b948002db3c3e0b262e ? EPG event?
and this is my example
<filter channel_id="00031713151e" >3effce16313706007800f1ff</filter> --CNN
is this correct or is something wrong.
Thanks
Re: WebGrabPlus
In Your example:
00031713151e is the channel id (generated by neutrino)
3effce16313706007800f1ff ist the name from the channel in your epg.xml file.
get channels-id from:
http://<boxip>/control/channellist
b3660514013e3ae9 AMC
a9ca2d50013e0de2 Animal Planet HD
a9ca2d50013e0db4 AXN SPIN HD
Get Egp name from xml:
<channel id="AnimalPlanetWest.us">
<display-name>Animal Planet West</display-name>
<icon src="https://cdn.tvpassport.com/image/station/100x100/animalplanet-19.png"/>
</channel>
in this case "AnimalPlanetWest.us"
so the entry in epgmap.xml
<?xml version="1.0" encoding="UTF-8" ?>
<zapit>
	<filter channel_id="a9ca2d50013e0de2" >AnimalPlanetWest.us</filter> --AnimalPlanet
	<filter channel_id="aa0004210001ef10" >RTL.de</filter> --RTL HD
	<filter channel_id="b6ba3db8013e4224" >RedlightHD.ero</filter> --Redlight HD
</zapit>
