<webtv genre="IPTV" title="Rakuten TV - Euronews" url="https://rakuten-euronews-5-de.samsung.wurl.com/manifest/playlist.m3u8" epgmap="DEBA3300029HT" script="best_bitrate_m3u8.lua" description="e2tv" />Code: Alles auswählen
<webtv genre="IPTV"
title="Rakuten TV - MovieDome"
url="https://moviedome-samsung.amagi.tv/playlist.m3u8"
epgmap="DEBA3300039TT"
#EXTM3U
#EXT-X-VERSION:3
#EXT-X-INDEPENDENT-SEGMENTS
#EXT-X-STREAM-INF:BANDWIDTH=1020800,AVERAGE-BANDWIDTH=985600,CODECS="avc1.64001e,mp4a.40.2",RESOLUTION=640x360,FRAME-RATE=25.000,CLOSED-CAPTIONS=NONE
playlist360_p.m3u8
#EXT-X-STREAM-INF:BANDWIDTH=2428800,AVERAGE-BANDWIDTH=2340800,CODECS="avc1.64001f,mp4a.40.2",RESOLUTION=960x540,FRAME-RATE=25.000,CLOSED-CAPTIONS=NONE
playlist540_p.m3u8
#EXT-X-STREAM-INF:BANDWIDTH=3572800,AVERAGE-BANDWIDTH=3440800,CODECS="avc1.64001f,mp4a.40.2",RESOLUTION=1280x720,FRAME-RATE=25.000,CLOSED-CAPTIONS=NONE
playlist720_p.m3u8
#EXT-X-STREAM-INF:BANDWIDTH=4716800,AVERAGE-BANDWIDTH=4540800,CODECS="avc1.640032,mp4a.40.2",RESOLUTION=1920x1080,FRAME-RATE=25.000,CLOSED-CAPTIONS=NONE
playlist1080_p.m3u8
function getMaxRes()
local maxRes = 1280
local Nconfig = configfile.new()
if Nconfig then
Nconfig:loadConfig("/var/tuxbox/config/neutrino.conf")
maxRes = Nconfig:getInt32("webtv_xml_quality", 1920)
end
return maxRes
Bei uns gibt es webtv_xml_quality nicht (mehr). Dort muss livestreamResolution stehen.
Diese Version ist identisch zu der, die wir im Plugin-Repo haben. https://github.com/neutrino-images/ni-n ... e_m3u8.lua
