HD1 von Rel.1.2 auf 3.3
dim666
Box: HD-1
Re: HD1 von Rel.1.2 auf 3.3
Beitrag von dim666 »
Vielen Dank für deine Arbeit :metal: :metal:
...aber wie gehabt....
Kernel wird nicht geflasht
System bootet nicht nach erfolgreichen flash
alles über NXPHDloader geflasht
Log mittels putty....
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ͻ
▒ U-Boot 2009.03-svn1366 (Nov 26 2009 - 14:54:37) Coolstream HD1 ▒
▒ Chipset information ▒
▒ Vendor: Conexant Type: CX2450x (Nevis) Revision: C0 Fuses: 76FFED34 ▒
▒ Option: 40810000 max. clock: 450 MHz Core voltage: high ▒
▒ Clock information ▒
▒ MPG0: 594.000 MHz MPG1: 594.000 MHz HD : 593.407 MHz AUD : 491.520 MHz ▒
▒ PLL0: 432.000 MHz PLL1: 450.000 MHz PLL2: 533.333 MHz ▒
▒ CPU : 450.000 MHz from PLL1 ▒
▒ Memory configuration ▒
▒ Start ▒ End ▒ Type ▒ Description ▒
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ĺ
▒ 00000000 ▒ 0FFFFFFF ▒ RAM ▒ System main memory bank #0 ▒
▒ 10000000 ▒ 17FFFFFF ▒ RAM ▒ System main memory bank #1 ▒
▒ F0000000 ▒ F1FFFFFF ▒ FLASH ▒ Spansion S29GL256P (256 Mbit / 16M x 16) ▒
▒ Serial number: 007-00000302 (07-00012E) ▒
▒ *** Warning - bad CRC, using default environment *** ▒
▒ Network configuration ▒
▒ MAC: Conexant VMAC rev. 07 address: 00-C5-5C-00-01-2E ▒
▒ PHY: IC Plus IP101 address: 09 ▒
▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒ͼ
Image Name: NI Nevis Kernel
Data Size: 2324644 Bytes = 2.2 MB
Load Address: 00048000
Entry Point: 00048000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.34.13-nevis (gandharva@Totoro) (gcc version 4.6.4 (crosstool-NG 1.19.0 - Linaro GCC 4.6 2013.05) ) #1 Sat Apr 2 16:48:32 CEST 2016
Machine: CST HDx IRD
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
Kernel command line: console=ttyRI0 mtdparts=cx2450xflash:512k(U-Boot)ro,4096k(kernel),28160k(systemFS) root=mtd2 rootfstype=jffs2 rw mem=384M
Memory: 384MB = 384MB total
Memory: 385008k/385008k available, 8208k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0x98800000 - 0xe0000000 (1144 MB)
lowmem : 0x80000000 - 0x98000000 ( 384 MB)
modules : 0x7e800000 - 0x80000000 ( 24 MB)
.init : 0x80048000 - 0x80063000 ( 108 kB)
.text : 0x80063000 - 0x8047f000 (4208 kB)
.data : 0x80480000 - 0x804a1a20 ( 135 kB)
NR_IRQS:352
console [ttyRI0] enabled
Calibrating delay loop... 448.92 BogoMIPS (lpj=2244608)
devtmpfs: initialized
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.22.1.
cfg80211: Calling CRDA to update world regulatory domain
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered tcp NFSv4.1 backchannel transport module.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 751
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
loop: module loaded
CX2450x MTD driver v1.0 (Apr 2 2016, 16:47:48) (c) Coolstream International Ltd.
number of CFI chips: 1
3 cmdlinepart partitions found on MTD device cx2450xflash
Creating 3 MTD partitions on "cx2450xflash":
0x000000000000-0x000000080000 : "U-Boot"
0x000000080000-0x000000480000 : "kernel"
0x000000480000-0x000002000000 : "systemFS"
arcvmac arcvmac: ARC VMAC at 0x80484580 irq 24 00:c5:5c:00:01:2e
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
cx2450x-ehci cx2450x-ehci.0: Trident CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.0: USB 0.0 started, EHCI 1.00
usb usb1: Product: Trident CX2450X EHCI USB-Controller
usb usb1: Manufacturer: Linux 2.6.34.13-nevis ehci_hcd
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
cx2450x-ehci cx2450x-ehci.1: Trident CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.1: USB 0.0 started, EHCI 1.00
usb usb2: Product: Trident CX2450X EHCI USB-Controller
usb usb2: Manufacturer: Linux 2.6.34.13-nevis ehci_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
ALSA device list:
No soundcards found.
TCP cubic registered
VFS: Mounted root (jffs2 filesystem) on device 31:2.
devtmpfs: mounted
Freeing init memory: 108K
init started: BusyBox v1.20.2 (2014-04-11 15:19:17 CEST)
Jan 01 01:00:02 (none) user.info rcS[41]: start
Jan 01 01:00:02 (none) user.info rcS[41]: creating system directories ...
Jan 1 01:00:03 NG-FLASH-000099 syslog.info syslogd started: BusyBox v1.20.2
Jan 1 01:00:03 NG-FLASH-000099 user.info rcS[41]: mdev coldplug ...
Jan 1 01:00:05 NG-FLASH-000099 user.info rcS[41]: init frontpanel ...
Jan 1 01:00:06 NG-FLASH-000099 user.info rcS[41]: init hardware ...
Jan 1 01:00:11 NG-FLASH-000099 user.info rcS[41]: init drivers ...
Jan 1 01:00:12 NG-FLASH-000099 user.info service[330]: running /etc/init.d/networking start
Configuring network interfaces... Starting ifplugd... done.
Jan 1 01:00:13 NG-FLASH-000099 daemon.err ifplugd(eth0): started: BusyBox v1.20.2 (2014-04-11 15:19:17 CEST)
Jan 1 01:00:13 NG-FLASH-000099 daemon.err ifplugd(eth0): using SIOCETHTOOL detection mode
Jan 1 01:00:13 NG-FLASH-000099 daemon.err ifplugd(eth0): link is down
Jan 1 01:00:13 NG-FLASH-000099 user.info service[355]: running /etc/init.d/ntpdate start
Jan 1 01:00:14 NG-FLASH-000099 user.info rcS[41]: run initscripts start ...
Jan 1 01:00:14 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S01NGfstab ...
Jan 01 01:00:14 NG-FLASH-000099 user.info S01NGfstab[395]: mount all local stuff from /etc/fstab
Jan 01 01:00:15 NG-FLASH-000099 user.info S01NGfstab[395]: mount all netfs stuff from /etc/fstab
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S53inetd ...
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S53vsftpd ...
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S55crond ...
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S60autofs ...
automount: /var/etc/auto.net is empty, cannot start
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S60dropbear ...
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S80inadyn ...
Jan 1 01:00:15 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S999NG99emu ...
[S999NG99emu] start oscamfix
[oscamfix] manipulating date ... done (201409032354) $
[S999NG99emu] start doscam
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99NG99fritzcallmonitor ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99djmount ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99nfsd ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99samba ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99tuxcald ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99tuxmaild ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99ushare ...
Sep 3 23:54:00 NG-FLASH-000099 user.info rcS[41]: starting /etc/init.d/S99xupnpd ...
Sep 03 23:54:00 (none) user.info rcS[41]: done
Sep 3 23:54:00 NG-FLASH-000099 daemon.info init: starting pid 487, tty '': '/etc/init.d/start_neutrino'
Please press Enter to activate this console. [neutrino] frameBuffer Instance created
/dev/fb/0: No such file or directory
framebuffer not available.
FBIOGET_FSCREENINFO: Bad file descriptor
[neutrino] Error while setting framebuffer mode
Neutrino exited with exit code 255
Box: Link Kabel
@dim666
Dann weiss ich auch nicht mehr weiter..... :pensive:
Könnte Dir höchstens noch U-Boot von meiner Sicherung aus November 2014 anbieten..... :thinking:
Hast du das mit dem Originalimage von 2014 auch probiert.... :neutral_face:
mirz hat geschrieben: ↑Mo 3. Apr 2017, 21:41 ne, hab ich nicht.
Aber damit könnte es auch gehen (CST-Image)
viewtopic.php?f=29&t=1135
Box: Link Kabel
@dim666:
Hab nochwas gefunden..... :wink:
Howto passender Kernel zum Image?
Sollte mal das Flashen schiefgegangen sein, und der Kernel nicht mit upgedatet worden sein, kein Problem.
Flasht einfach den passenden Kernel per Emergency-Flash nach.
Wie kommt man nun zum passenden Kernel?
Ladet euch das Image runter, das ihr flashen wollt / bzw. geflasht habt.
Nehmt euch das Programm Newtuxflash
NewTuxFlash.rar
(538.24 KiB) 397-mal heruntergeladen
Startet die Newtuxflash.exe
Wählt über "Datei öffnen" das Image wovon ihr den Kernel benötigt.
Der Kernel liegt hier unter:
/jffs2/var/update/ >>>uImage
Dieses uImage zieht ihr z.b. auf den Desktop und nennt es in kernel.img um.
Diesen Kernel könnt ihr dann per USB-Stick und Emergency-Flash nachflashen.
Quelle: 3ultra 11.09.2012-aus einem anderen Board-
stefanx
Box: Alle CST SAT
Been thanked: 13 times
Beitrag von stefanx »
das man mit den "uralt" Images und den alten Dateien für die Wiederherstellung mittels NXPHDloader NICHT auf das aktuelle NI flashen kann ist ein alter Hut.
Ich habe darüber bereits öfter berichtet.
Deshalb flashe ich immer zuerst ZB. NG2.7 und dann erst das aktuelle NI.
Betrifft eigentlich die komplette HD1 Serie, wobei die neueren Neos und Zee's dann zumindest per USB wiederhergestellt werden können. Für die älteren Modelle kann ich den NXPHDloader empfehlen, wobei ich auch unterschiedleiche Dateisets je nach Box verwende.
Es gibt eeventuell einen einfacheren Weg, jedoch meiner funktionierte immer sehr zuverlässig.
NG2.7 flashen, update.url ändern bzw. aktuelles NI3.3 über FTP oder per Stick lokal installieren.
gandharva
Box: Tank
Beitrag von gandharva »
Im Log sehe ich das der Kernel zu neu ist. Das Image stammt aus 2014 (siehe Busybox init) und der Kernel aus 2016.
Im Prinzip sollte es reichen per USB ein Image zu flashen das zum Kernel passt.
Versuch mal damit: http://www.neutrino-images.de/neutrino- ... -nevis.img
Und mit dieser Anleitung: http://neutrino-images.de/board/viewtopic.php?f=47&t=8
Du brauchst nur das Image aus dem ersten Link und nicht die Dateien aus der Anleitung!
Nazi lives don't matter.
Box: Link Kabel
gandharva hat geschrieben: ↑Mi 5. Apr 2017, 10:08 Im Log sehe ich das der Kernel zu neu ist. Das Image stammt aus 2014 (siehe Busybox init) und der Kernel aus 2016.
@gandharva:
Seltsam..... :no_mouth: Wenn es "meine" hochgeladenen Dateien betrifft.... :thinking:
Image ist von 2014 und der Kernel eigentlich auch, das hatte ich im September 2014(Image) bzw. November 2014(Kernel) mit einzelne Partionen ausgelesen.... :open_mouth:
dim666
Box: HD-1
Guten Abend,
ein kurzes Feedback über den aktuellen Stand:
Flash via NXPHD
1. Rel 1.2 Kernel ok
System ok
... Box funktioniert
ab hier keinen Kernel mehr geflasht
2. Rel 2.14 System ok
3. Rel 2.7 System ok
... Box funktioniert ----Danke ncfs----
4. Rel 3.3 System ok
5. via Service wurde ein Update vom 4.4.2017 gefunden
*Flash erfolgreich ausgeführt
*Box bootet
*bleibt bei....139...hängen
>>>>>weiter geht es morgen
Vielen Dank an Alle die sich hier beteiligen.
dim666
dim666
Box: HD-1
@granharva
via putty habe ich es nicht zum laufen bekommen.
beim ersten Versuch habe ich wohl " start usb" überlesen
Danach hat alles funktioniert wie beschrieben.
Aber nach dem flashen via putty, ist die Box bei "Boot Kernel" hängen geblieben.
Allerdings habe ich hier die Chronologie der Softwarestände nicht eingehalten.
Nagele mich jetzt nicht fest, leider habe ich die Schitte nicht dokumentiert.
Box: Link Kabel
@dim666:
Probier mal direkt von 2.70 auf 3.30 vom 04.04.... :thinking:
und bitte alles ohne irgendwelche Settingsübernahmen usw....arbeite den Einstellungsassi ruhig mal ab.... :rolling_eyes:
bei Knicko hat das heute auch gefunzt...... :wink:
Knicko hat geschrieben: ↑Mi 5. Apr 2017, 20:51 hab heute von 2.70 bei der Neo auf das neue Image aktualisiert, ohne Probleme.
stefanx
Box: Alle CST SAT
.. klarer Weise KEINE alten Einstellungen oder sonstiges Zeugs einspielen.
wie oben von ncsf erwähnt die Einstellungen wieder einmal manuell vornehmen.
Die Senderlisten können natürlich eingspielt werden.
//edit devil7: Beitrag angepasst wegen Nichtbeachtung der Board-Regeln.
dim666
Box: HD-1
Einstellungen habe ich keine zurück gespielt.
Nach erfolgreichen Flash hatte ich die Box gebootet und gleich das nächste Image drauf geladen.
Jetzt probiere ich aus von 2.7 via Update auf aktuellen Stand.
Mehr dann später...
dim666
Box: HD-1
Es kommt immer wieder Fehler 139
HD1> usb start
(Re)start USB...
USB: ehci_hcd_init();
CX2450x init hccr e8000100 and hcor e8000140 hc_length 64
Register 10011 NbrPorts 1
USB EHCI 1.00
HD1> fatload usb 0 0x0E000000 mtd2.img
reading mtd2.img
27394048 bytes read
HD1> erase 0xF0480000 0xF1FFFFFF
Erased 220 sectors
HD1> cp 0x0E000000 0x688000
Usage:
cp - memory copy
HD1> cp 0x0E000000 0xE0480000 0x688000
Copy to Flash... Unknown Type of Flash
HD1> cp 0x0E000000 0xF0480000 0x688000
Copy to Flash... .................................................................................................................................................................................................................
done
HD1> reset
OK
Starting kernel ...
NR_IRQS:352
TCP reno registered
brd: module loaded
loop: module loaded
usb 1-1: new high speed USB device using cx2450x-ehci and address 2
ALSA device list:
usb 1-1: New USB device found, idVendor=058f, idProduct=6387
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: Mass Storage
usb 1-1: Manufacturer: Generic
usb 1-1: SerialNumber: 9CB9B257
scsi0 : usb-storage 1-1:1.0
devtmpfs: mounted
scsi 0:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 2
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 7872512 512-byte logical blocks: (4.03 GB/3.75 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1 sda2
sd 0:0:0:0: [sda] Attached SCSI removable disk
init started: BusyBox v1.20.2 (2017-04-04 11:38:10 CEST)
Jan 01 01:00:03 (none) user.info rcS[45]: start
Jan 01 01:00:03 (none) user.info rcS[45]: creating system directories ...
Fri Jan 1 00:00:00 CET 2016
running /sbin/mknodes
rootdir=/dev
table=<stdin>
done /sbin/mknodes
Jan 1 00:00:00 NI-FLASH-00012E syslog.info syslogd started: BusyBox v1.20.2
Jan 1 00:00:00 NI-FLASH-00012E user.info rcS[45]: init frontpanel ...
Jan 01 00:00:01 NI-FLASH-00012E user.info stb_update.sh[96]: Kernel already up-to-date
Jan 1 00:00:02 NI-FLASH-00012E user.info rcS[45]: mdev coldplug ...
Jan 1 00:00:02 NI-FLASH-00012E user.info mdev-mount: [] mounting /dev/sda1 to /media/sda1
Jan 1 00:00:04 NI-FLASH-00012E user.info mdev-mount: [] mounting /dev/sda2 to /media/sda2
Jan 1 00:00:12 NI-FLASH-00012E user.info rcS[45]: init hardware ...
Jan 1 00:00:17 NI-FLASH-00012E user.info rcS[45]: init drivers ...
Jan 1 00:00:18 NI-FLASH-00012E user.info service[930]: running /etc/init.d/networking start
Configuring network interfaces... udhcpc (v1.20.2) started
Sending discover...
Sending discover...
Sending discover...
No lease, failing
Starting ifplugd... Jan 1 00:00:28 NI-FLASH-00012E daemon.err ifplugd(eth0): started: BusyBox v1.20.2 (2017-04-04 11:38:10 CEST)
done.
Jan 1 00:00:28 NI-FLASH-00012E daemon.err ifplugd(eth0): using SIOCETHTOOL detection mode
Jan 1 00:00:28 NI-FLASH-00012E daemon.err ifplugd(eth0): link is down
Jan 1 00:00:28 NI-FLASH-00012E user.info service[956]: running /etc/init.d/ntpdate start
insmod: can't insert '/lib/modules/2.6.34.13-nevis/fuse.ko': File exists
Jan 1 00:00:30 NI-FLASH-00012E user.info rcS[45]: run initscripts start ...
Jan 1 00:00:30 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S01fstab ...
Jan 01 00:00:30 NI-FLASH-00012E user.info S01fstab[1014]: mount all local stuff from /etc/fstab
Jan 01 00:00:30 NI-FLASH-00012E user.info S01fstab[1014]: mount all netfs stuff from /etc/fstab
Jan 1 00:00:30 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S53inetd ...
Jan 1 00:00:30 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S53vsftpd ...
Jan 1 00:00:30 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S55crond ...
Jan 1 00:00:30 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S60autofs ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S60dropbear ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S60nfsd ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S80inadyn ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99NI99emmrd ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99NI99emu ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99NI99fritzcallmonitor ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99djmount ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99samba ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99tuxcald ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99tuxmaild ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99ushare ...
Jan 1 00:00:31 NI-FLASH-00012E user.info rcS[45]: starting /etc/init.d/S99xupnpd ...
Jan 01 00:00:31 (none) user.info rcS[45]: done
Jan 1 00:00:31 NI-FLASH-00012E daemon.info init: starting pid 1064, tty '': '/etc/init.d/start_neutrino'
Please press Enter to activate this console. [neutrino] Coolstream HD1 framebuffer Instance created
>FBACCEL::INIT
[fb_generic] [CX2450X] framebuffer 14400k video mem
[fb_accel_cs_hd1] 14400k video mem
[fb_accel_cs_hd1] 1280x720x32 line length 5120. using CX2450X graphics accelerator.
KAL Trace Initializaing ...
KAL Trace init Complete
KAL mmap'ings:
cached[0] = 0x31bd8000 (0x01400000)
uncached[0] = 0x31dd8000 (0x06c00000)
content[0] = 0x37cd8000
cached[1] = 0x3d0d8000
uncached[1] = 0x3d0d8000
content[1] = 0x3e4d8000
CSAPI (VIDEO): video init: 1
CSAPI (API): CST API coolstream-mt-3.2.0 initialized on Rev. 7 Serial Nr 216998927663406
[femanager.cpp:getFE:497] Frontend #0 not found
Segmentation fault
Neutrino exited with exit code 139
ich gehe jetzt mal Sonne tanken.
Hallo dim666 , habe mitgelesen - stefanx hat in Post 24 geschrieben " NG2.7 flashen, update.url ändern bzw. aktuelles NI3.3 über FTP oder per Stick lokal installieren "
also erneut NG 2.7 flashen und dann NI.3.3 nur über FTP oder per Stick lokal ! erneut versuchen ...
Viel Glück - imi8mm
dim666
Box: HD-1
Hallo imi8mm,
diesen Schritt habe ich ebenfalls ausgeführt.
Rel 2.7 geflasht, Ersteinrichtung manuell durchlaufen lassen,
update.url per ftp auf die Box geschickt und Rel 3.3 vom 04.04. lokal installiert.
...Fehler....
dim666
stefanx
Box: Alle CST SAT
offenbar ist mit dem letzten 3.3 was nicht ganz OK, habe auch gleich 2 BSE mit Neutrino 139 bekommen.
Das mit dem 2.7 ist natürlich nur notwendig wenn man ein älteres Image oder Fremdimage drauf hat.
Ich werde jetzt vorerst auch eines von vor dem 4.4. raussuchen müssen um meine 2 BSE-Boxen wieder einsatzbereit zu bekommen.
ich habe gestern erst meine Neo² per Online-Update auf das Image vom 4.4.17 upgedatet, ohne Probleme, also ganz kaputt ist es nicht.
Vllt liegt es an den Boxen (ihr hattet alle die alten HD1/BSEs oder? Also keine Neo,Zee,Neo²? ), oder aber an was anderem, zB bestehendem Online-Zugang (hattet ihr offline upgedatet?)...
stefanx
Box: Alle CST SAT
.. ich denke, es hat was mit den HD1 Boxen der ersten Serien zu tun, denn an meinen Boxen war nichts besonderes, nur doscam.
Auch habe ich eine Box online und eine offline geflasht und das gleiche Ergebnis bekommen.
An den Zufall glaube ich in diesem Fall auch nicht, da ich nicht der einzige bin.
Ich werde das heute am Abend genauer anschauen, da ich jetzt wieder zu Hause bin un die Boxen mit habe.
Box: Link Kabel
stefanx hat geschrieben: ↑Mo 10. Apr 2017, 08:39 .. ich denke, es hat was mit den HD1 Boxen der ersten Serien zu tun,
Weis jemand bis wann "die Erste Serie" ungefähr ging..... :rolling_eyes:
Meine HD 1C habe ich im März 2010 bekommen, da lasse ich jetzt mal alles auf RR vom März lieber.... :thinking:
stefanx
Box: Alle CST SAT
Unter erster Serie verstehe ich die HD1, HD1-BSE, Zee und Neo ohne Netzschalter.
Das sind auch die Boxen wo noch keine Wiederherstellung über nur USB geht. Also diejenigen wo man mit dem Com-Kabnel und dem Loader ran muss.
Soeben eine BSE wiederbelebt, dann NG 2.7 und dann online geflasht - leider Neutrino 139!
Ich werde vorerst keine der alten Serie mit dem aktuellem 3.3 vom 4.4. mehr flashen.
Hat eventuell jemand das letzte Image vor dem 4.4.?
Has thanked: 17 times
Been thanked: 12 times
Es wird dran gearbeitet. Denkt bitte nicht, dass es keinen interessiert, aber User mit alter Hardware gibt es nicht mehr so viele. Im Moment würde ich allerdings auch die Finger vom flashen der BSE mit aktuellem Image lassen. Lasst uns etwas testen, micha-bbg ist da schon dran .
