Zee tuner
lilo74
Box: Mutant HD51.Coolstream Trinity sat
Zee tuner
Beitrag von lilo74 »
Hi all forum,Where can i buy a tuner Zee sat? :cry:
Mutant HD51,2Coolstream Trinity Sat, Vu+solo seV2,edision argus pingulux plus,Azbox Me,golden media one,2 coolstream zee DVB-S2 and DVB-C
stefanx
Box: Alle CST SAT
Re: Zee tuner
Beitrag von stefanx »
lilo74
Re: Zee tuner
no friend, I need only tuner DVB-S2 Full plate.
wutz
Re: Zee tuner
Beitrag von wutz »
There is no way getting parts somewhere....
lilo74
Re: Zee tuner
Thanks all,I'll wait If someone has a second hand,I do not care I buy.
Re: Zee tuner
think about what you are buying, keeping old hardware running might be expensive.
On the Ebay-link there was also an offer for a new Coolstream Zee below of the site http://www.ebay.de/itm/Coolstream-CST-T ... 0005.m1851
OK, B-ware (might have some damage but do you believe a receiver in use for some years look really new ?), from a shop-seller = warranty (might only be 1 year). Basically features are the same, the operating system looks similar, the TV program is also the same crap but it has a faster processor, external power supply (old boxes with internal power supply have often power supply failure after some years)
lilo74
Re: Zee tuner
Ok Thanks.
