Und wieder ein neuer mit Problemen
flk
Been thanked: 21 times
Re: Und wieder ein neuer mit Problemen
Beitrag von flk »
reading uldr.bin
** Skipping uldr.bin **
reading u-boot.bin
** Skipping u-boot.bin **
Das hatte aber beim vorherigen Log geklappt.
Dafür kann jetzt das nand gelesen werden :D
lipps1
Box: Trinity, Trinity duo
Beitrag von lipps1 »
So alle Dateien noch mal neu geladen und umbenannt.
Und hier der Bootlog dazu.
CST HD2 # =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2017.08.12 21:13:23 =~=~=~=~=~=~=~=~=~=~=~=
Starting Microloader ASM built on 08 2015 10:29:32...
Initializing PLLs...
Initializing Clocks..
Initializing data section...
Initializing stack ptr...
Switching to 'C' code...
Starting Microloader C...
Chip: KRONOS
Found Internal MYSTI110 PHY on GMAC0
GCS in ISA MODE
BOX MAC OK!
BOX: Type: TRINITY V2 Rev: 7530C100
Jumping to U-Boot ...
BOOT_TIME: 574 ms since POR
| U-Boot 2009.08-00067-gebbd4b2 (Apr 03 2015 - 16:38:15) CST HDx |
| Chipset information |
| Vendor: Entropic Type: KRONOS Revision: B0 Fuses: 00010001 |
| Clock information |
| *** not available yet *** |
| Frontpanel information |
| Memory configuration |
| 00000000 | 1FFFFFFF | RAM | System main memory bank #0 (512M) |
0% 3% 6% 9% 12% 15% 18% 21% 24% 28% 31% 34% 37% 40% 43% 46% 49% 53% 56% 59% 62% 65% 68% 71% 74% 78% 81% 84% 87% 90% 93% 96% 99% *** Warning - bad CRC or SFC, using default environment
| 00000000*| 07FFFFFF*| NAND | Toshiba NAND 128MiB 3,3V 8-bit |
| Network configuration |
| MAC: LIP 6300 address: 00-C5-5C-3E-91-13 |
Emergency update from usb
(Re)start USB...
USB EHCI 1.00
reading uldr.bin
reading u-boot.bin
reading env.bin
0 bytes read
SFC erase: e0631000.flash_nand: partitioning exceeds flash size
'env' is not a number
** Error erasing SFC for env **
reading vmlinux.ub.gz
2898001 bytes read
'kernel' is not a number
** Error erasing SFC for vmlinux.ub.gz **
reading rootfs.arm.jffs2.nand
52449044 bytes read
NAND erase: e0631000.flash_nand: partitioning exceeds flash size
'root0' is not a number
** Error erasing NAND for rootfs.arm.jffs2.nand **
reading var.arm.jffs2.nand
resetting ...
Chip: KRONOS
GCS in ISA MODE
BOX MAC OK!
BOOT_TIME: 572 ms since POR
| Clock information |
Hit any key to stop autoboot: 3 2 1 0
SFC read: e0631000.flash_nand: partitioning exceeds flash size
Wrong Image Format for bootm command
CST HD2 #
flk
Beitrag von flk »
Sieht aus, als wäre dein env verbogen. Gehe nochmal nach Gandharvas Anleitung vor. Diesmal kann ja das nand gelesen werden.
Has thanked: 44 times
Been thanked: 78 times
env.bin ist die einzige Datei von dem Stick, die gelesen werden kann. ^^
Davor müssen aber uldr und u-boot passen ... und da hakt es, wie es scheint.
reading uldr.bin
reading u-boot.bin
reading env.bin
0 bytes read
flk
Beitrag von flk »
52449044 bytes read
Das .nand wird jetzt auch gelesen, aber kann halt nicht geschrieben werden.
uboot und uldr hat lipps1 (warum auch immer) vor den letzten Versuchen wieder vom Stick gelöscht
lipps1
Hallo Gemeinde Danke für die tollen Hilfen. Ich habe noch einmal ganz von vorn angefangen und siehe Da sie läuft wieder. Jetzt noch einmal eine Werksreset, den ich noch nicht gefunden habe und dann sollte sie es wieder Komplett tun. Also danke noch mal an alle war bestimmt eine schwere Geburt mit mir. Aber wie ich mich kenne passiert mir das bestimmt nochmal.
Grüße Lipps
PS: jetzt noch die Suche bemühen für die Werkseinstellung.
lipps1
So alles erledigt und Werkseinstellung geladen, danach aktuelle Release über Softwareaktualisierung geladen und los gings.
Danke noch mal an alle
Grüße Lipps
