NI-Image 3.3 (Changelog) - Rolling Release
Gesperrt
Has thanked: 20 times
:N:eue :I:mages für alle Boxen online.
:I:mage:
- bump image version to 3.30
- icons: add some more material design icons
- icons: remove obsolete hint-icons
- add "Material-Design" icons
- install our full "Material-Design" icons as default
- iconsets: use "Material-Design" icons for iconset-pkg0
- icons: remove obsolete icons
:N:eutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... 7fb106c78b)
- bump neutrino version to 3.30
- themes: change text color on cursor to black
- icons: add and use pictureviewer icon
- usermenu: sort NI code to original code
- infoicons: simplify icon detection
- usermenu: allow testmenu in usermenu
- don't use casystem frame per default
- themes: change default colors
- add our new "Material-Design" icons
- infoviewer_bb: use just 1px for ca-bar frame
- iconsets: rename pkg0-iconset to "Material-Design"
- infoviewer_bb: enlarge ca_bar by 2 pixels
- infoviewer_bb: disable broken infobar_casystem_dotmatrix code
- channellist: remove obsolete NI-code
- infoicons: use OFFSET defines; increase offset between icons
- icons: move NI icons into categorized subdirectories
- cc_frm_header: try to fix clock; e.g. in timerlist
- configure.ac: change package name/version
- bouquets.cpp: remove linebreak from auto-epg console message
- capmt: fix include to get g_settings
- followscreenings.cpp: Fix option "always"
- capmt.cpp: Allow to disable the NI CI-Record workaround if option "usable CI channel while recording" set to "all channels"
- capmt.cpp: Codeing the NI CI-Record workaround closer to original
- helpbox: use a smoother color and a smaller height for separatorline
- themes: make Material Gray (dark) theme a bit darker
- themes: add Material Gray (Medium) theme
- infoviewer: move ICON_CA to the left
- cc_frm_footer.h: use proven COL_SHADOW_PLUS_0 for button frames
- locale: adapt last changes to our locales
Re: NI-Image 3.3 (Changelog) - Rolling Release
:I:mage:
- libpng: bump version to 1.6.28
- zlib: bump version to 1.2.11
- openvpn: bump version to 2.4.0
- upgrade fahrplan plugin; v2.1
- plugins: fix build of shellexec, msgbox and input
- freetype: bump version to 2.7.1; align freetype2_subpixel.patch
- inadyn.init: binary now placed in /sbin; allow to stop w/o flagfile
- inadyn: bump version to 2.1
- icons: update Material-Design icon set
- webtv: upgrade hdporntv stuff
:N:eutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... 58e25a69f3)
- themes: better visibility for progressbars
- icons: better visibility for some icons
- icons: rework channel-status icons
- infoviewer_bb: use larger offsets for channel-status icons
- infoviewer_bb: don't use a smaller icon-offset in ca-bar's discrete mode
- infoviewer_bb: use 10px offset for left ca-icons
- locale: fix funny typo
- icons: small changes as suggested by team
- themes: use color from material palette for progressbar-background
- themes: upgrade our themes
- theme: use new PB_MONO as default
- theme: add adulterated orange theme (the old default theme)
- OSD Menu: Add progressbar color
- controlapi: add possibility to check for updates
- NI-yWeb: small whitespace cleanup
- NIyWeb: fix display of imageinfo ... and disable online check; needs several fixes
Im Tuxbox-Neutrino-Repository wurden auch die Plugins shellexec, msgbox und input überarbeitet. Vielen Dank an GetAway für die Mitarbeit. Diese Plugins sind natürlich auch - wie immer - mit im Image.
Die Darstellung unserer Icons ist nun deutlich besser geworden. Danke an micha-bbg für den Fix.
Die neuen Framebuffer-Module von Focus sind ebenso mit drin. Damit ist es nun möglich, die Neutrino-GUI in FullHD (1920x1080) darzustellen. Es steht da aber noch jede Menge Arbeit im Raum. Deswegen ist die alte Auflösung (1280x720) noch default.
Viel Spaß mit den :I:mages. :)
:N:eue :I:mage-Updates für alle Boxen online.
Grundlage für dieses Update ist das letzte Rolling Release vom Dienstag, dem 24.01.2017. Ob das Update auch in älteren Images läuft, kann ich nicht versprechen.
:N:eutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... =ni/tuxbox)
Im Tuxbox-Neutrino-Repo wurde der Entwicklungszweig pu/font in den Master-Branch übernommen.
Es hat sich also beim Rendern der Schrift einiges getan.
Viel Spaß mit den Updates.
:N:eutrino:
* "nur" aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... =ni/tuxbox)
:N:eutrino:
Die Zeitanzeige im Movieplayer wurde repariert. Danke, Micha. :ok_hand:
:I:mage:
- openvpn_setup: update to v0.17; scale2Res() for FullHD
- add-locale: use scale2Res() for FullHD
- userbouquets: update to v0.12; scale2Res() for FullHD
- fix coolithek's url and dependencies
- skel-root/hd2: disable 1920x1080 by default
- add exfat-utils to image (still broken!)
- busybox: bump version to 1.26.2
- openssl: bump version to 1.0.2k
- bash: add 4.4 paches
- pugixml: bump version to 1.8; fix build
- tzdata/tzcode: bump version to 2016j
- libgpg-error: bump version to 1.26
- libgcrypt: bump version to 1.7.6
- add and use patch to fix fbshot in FullHD-mode
:N:eutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... 69e12b2002)
- align new osd-presets to good old NI-values
- ni-menu; fix build; OSD-Scart-Fix needs fixes, as it seems
- capmt: remove newlines from debug output
- ni-menu: remove obsolete usage of screen_width/height
- mod_yparser.cpp: add missing defines to define-get function
- try to port our framebuffer changes (need fixes!)
- configure.ac: fix native build
An Neutrino selbst gibt es von unserer Seite kaum Änderungen. Im Tuxbox-Neutrino hat sich jedoch jede Menge getan. So ist nun eine Umschaltung des OSD auf FullHD, also 1920x1080, möglich. Jedoch muss man sagen, dass das alles noch in den Kinderschuhen steckt. Perfekt funktioniert es noch nicht. Drum ist diese Feature bei uns im Image auch per default deaktiviert.
Wer da dennoch mittesten möchte, kann sich das Flagfile /var/etc/.allow_fullhd anlegen. Danach muss die Box neu gestartet werden. Erst dann kann man die Auflösung umstellen. Beachtet jedoch, dass ein TV vonnöten ist, der 1080p oder 1080i darstellen kann. Wer ein 720p- oder entsprechendes HD-ready-Gerät hat, braucht nicht umzustellen. Der Fernseher würde das nur wieder runterskalieren. Der Effekt ginge also verloren.
Und wer nicht genau weiß, was ein Flagfile ist und wer ein stabiles OSD haben möchte, lässt bitte die Finger davon. :)
Für die Mutigen unter euch:
touch /var/etc/.allow_fullhd && reboot
Wer wieder zurück zur "alten" HD-Auflösung möchte, stellt sich bitte im OSD-Setup wieder die 1280er Auflösung ein, entfernt das Flagfile und startet die Box neu.
:I:mage:
- skel-root/hd2: fix framebuffer.ko parameters for FullHD
:N:eutrino:
* aktueller :NI:-Neutrino git-Stand (https://bitbucket.org/neutrino-images/n ... 9dab8e0bd6)
- imageinfo_ni: several fixes for FullHD display
- imageinfo_ni: add yWeb version
- imageinfo_ni: add Lua-API version
Die Abstürze, wenn keine services.xml bzw. keine ubouquets.xml vorhanden sind, wurden von SatBaby gefixt.
Dies ist also "nur" ein Bugfix-Image. Deswegen auch die relativ kleine Liste an Änderungen. Das komplette Changelog steht im Beitrag obendrüber.
Grundlage für dieses Update ist mindestens das Rolling Release vom Freitag, dem 03.03.2017. Ob das Update auch in älteren Images läuft, kann ich nicht versprechen.
:N:eutrino:
- imdb: align timeouts; use neutrino defaults
:I:mage:
- xupnpd: fix build; align dynamic-lua patch
- add libfribidi for hd2
- disable FONT keyword in shellexec and all included scripts
- FritzInfoMonitor: align to new neutrino.conf keywords
- gboxinfo: align to new neutrino.conf keywords
- oscammon: align to new neutrino.conf keywords
- oscammon: align and cleanup conf-files
- oscammon: replace NG-icon by a beautiful and awesome NI-icon
- pr-auto-timer: v0.40 (needs some more fixes!)
:N:eutrino:
- enable fribidi for hd2
- framebuffer: fix unscaled paintings; this fixes our starbar in imdb and tmdb
- imdb: fix segfaults whe api is changed; we only grab what we need
- lcd4l: add support for mode_upnp
- menue: fix lcd4l-support for directly started items
- lcd4l: fix display of webtv-channels on external lcd
- imageinfo_ni: add some more items
Gesperrt
