Cables.xml Aktualisierung
Has thanked: 171 times
Mir ist aufgefallen das die Cables.xml auf einem "vorsintflutlichen" ;) Stand ist. (Zumindest was den Anbieter WTC SN betrifft).
Hier mal der aktualisierte Ausschnitt:
<cable name="WTC SN" satfeed="true" flags="9">
		<transponder frequency="113000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="121000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="130000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="306000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="314000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="322000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="466000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="474000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="482000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="490000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="498000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="506000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="514000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="522000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="530000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="538000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="546000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="554000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="562000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="570000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="586000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="786000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="794000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="802000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="810000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
	</cable>
Has thanked: 51 times
Been thanked: 87 times
Re: Cables.xml Aktualisierung
Danke. Ist eingecheckt und also im nächsten Image mit enthalten.
:point_right: https://github.com/tuxbox-neutrino/gui- ... 54f49ece39
