AutoQ3D CAD 5.12
trapped
Been thanked: 3 times
AutoQ3D CAD 5.12
Beitrag von trapped »
Giveaway of the day — AutoQ3D CAD 5.12
AutoQ3D CAD for Windows is a full 2D and 3D CAD application that allows you to create, edit and share your drawings and designs. It lets you create fast 2D and 3D models and It is intended for everybody as professionals, sketchers, architects, engineers, designers, students and more.
Preset Views
·See your drawings from different points of view.
·View your 3D models using orthogonal and isometric preset viewpoints.
·Adjust the view of a 3D drawing by panning, zooming and rotating a view.
·Preset: top, front, right, bottom, back, left, isometric.
Drawing Tools
·Create models using three dimensions shapes such as lines, spheres, boxes and much more.
·Draw your own surfaces from 2D primitives using extrude and revolve.
·Tools: line, circle, rectangle, arc, polygon, text, triangles, box, sphere, camera, region, extrude, revolve.
Modification Tools
·These tools will help you to edit 3D models using some basic operations.
·Tools: erase, snapline, round, trim, fillet, offset, extend, explode, slice, texture uv, normals.
Snapping Tools
·Increase the accuracy of creating and modifying objects.
·You can draw to the mid-point or from the end-point of an object.
·Tools: end-point, mid-point, nearest, intersection, center, grid.
Group Tools
·Organize objects by groups allows you to handle easier large 3D models.
·Grouping functions are useful to manage several objects as one entity simplifying the process of edit them.
Edit Tools
·Edit Tools: move, scale, stretch, rotate, array, mirror.
And more...
Link
mfG
Trapped
Kein Support per PN/Mail
