Neo² - Ni-Image 3.3 startet nicht
mcbane
Beitrag von mcbane »
Hallo Zusammen,
Leider will euer Image/Kernel (kein Debug) bei mir nicht starten. Belibt immer bei "Boot Kernel" stehen. Siehe Log:
Boot 2009.03-svn1773 (Nov 02 2010 - 15:25:47)     Coolstream HDx
ipset information                                                           Vendor: Conexant  Type: CX2450x (Nevis)  Revision: D0       Fuses: 7EFE6D24   Option: 00010000  max. clock: 600 MHz    Core voltage: high
ock information                                                             MPG0: 594.000 MHz  MPG1: 594.000 MHz  HD  : 593.407 MHz  AUD : 491.520 MHz    PLL0: 432.000 MHz  PLL1: 594.000 MHz  PLL2: 533.333 MHz                       CPU : 594.000 MHz from PLL1
mory configuration                                                          Start    d      pe  scription
000000 FFFFFF M   stem main memory bank #0                      10000000 FFFFFF M   stem main memory bank #1                      F0000000 FFFFFF ASH ansion S29GL256P (256 Mbit / 16M x 16)
rial number: 008-00011539 (08-002D13)                                       *** Warning - bad CRC, using default environment ***
twork configuration                                                         MAC: Conexant VMAC rev. 07       address: 00-C5-5C-00-2D-13                   PHY: IC Plus IP101               address: 09                                 rror: Bad gzipped data
Error: no valid bmp or bmp.gz image at f0060000
Hit any key to stop autoboot:  0
   Image Name:   NI Nevis Kernel
   Data Size:    2324644 Bytes =  2.2 MB
   Load Address: 00048000
   Entry Point:  00048000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.34.13-nevis (gandharva@Totoro) (gcc version 4.6.4 (crosstool-NG 1.19.0 - Linaro GCC 4.6 2013.05) ) #1 Sat Apr 2 16:48:32 CEST 2016
Machine: CST HDx IRD
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97536
Kernel command line: console=ttyRI0 mtdparts=cx2450xflash:384k(U-Boot)ro,128k(Splash),4096k(kernel),28160k(systemFS) root=mtd3 rootfstype=jffs2 rw mem=384M
Memory: 384MB = 384MB total
Memory: 385008k/385008k available, 8208k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0x98800000 - 0xe0000000   (1144 MB)
    lowmem  : 0x80000000 - 0x98000000   ( 384 MB)
    modules : 0x7e800000 - 0x80000000   (  24 MB)
      .init : 0x80048000 - 0x80063000   ( 108 kB)
      .text : 0x80063000 - 0x8047f000   (4208 kB)
      .data : 0x80480000 - 0x804a1a20   ( 135 kB)
NR_IRQS:352
console [ttyRI0] enabled
Calibrating delay loop... 593.10 BogoMIPS (lpj=2965504)
devtmpfs: initialized
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.22.1.
cfg80211: Calling CRDA to update world regulatory domain
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered tcp NFSv4.1 backchannel transport module.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 751
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
loop: module loaded
CX2450x MTD driver v1.0 (Apr  2 2016, 16:47:48) (c) Coolstream International Ltd.
number of CFI chips: 1
4 cmdlinepart partitions found on MTD device cx2450xflash
Creating 4 MTD partitions on "cx2450xflash":
0x000000000000-0x000000060000 : "U-Boot"
0x000000060000-0x000000080000 : "Splash"
0x000000080000-0x000000480000 : "kernel"
0x000000480000-0x000002000000 : "systemFS"
arcvmac arcvmac: ARC VMAC at 0x80484580 irq 24 00:c5:5c:00:2d:13
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
cx2450x-ehci cx2450x-ehci.0: Trident CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.0: USB 0.0 started, EHCI 1.00
usb usb1: Product: Trident CX2450X EHCI USB-Controller
usb usb1: Manufacturer: Linux 2.6.34.13-nevis ehci_hcd
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
cx2450x-ehci cx2450x-ehci.1: Trident CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.1: USB 0.0 started, EHCI 1.00
usb usb2: Product: Trident CX2450X EHCI USB-Controller
usb usb2: Manufacturer: Linux 2.6.34.13-nevis ehci_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
ALSA device list:
  No soundcards found.
TCP cubic registered
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000000: 0x0527 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000004: 0xb913 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000008: 0xe358 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000000c: 0x2300 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000010: 0x0400 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000014: 0x0400 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000018: 0x00aa instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0000001c: 0x0205 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000020: 0x494e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00000024: 0x7665 instead
Further such events for this erase block will not be printed
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020000: 0xb187 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020004: 0x911e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020008: 0xb4f8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002000c: 0x46f9 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020010: 0x5d30 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020014: 0xf776 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020018: 0xde61 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0002001c: 0x3868 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020020: 0x1738 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00020024: 0xa632 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040000: 0xf041 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040004: 0x7fa2 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040008: 0x9154 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004000c: 0x7923 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040010: 0x297d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040014: 0xe49d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040018: 0xfb91 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0004001c: 0x3184 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040020: 0x8650 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00040024: 0x43c8 instead
Old JFFS2 bitmask found at 0x00058424
You cannot use older JFFS2 filesystems with newer kernels
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060000: 0x79db instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060004: 0x7206 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060008: 0x95bb instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006000c: 0xc513 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060010: 0xeb8d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060014: 0x5d7f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060018: 0x8677 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0006001c: 0x8b91 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060020: 0x3932 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00060024: 0x4efb instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080000: 0x3be7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080004: 0x3a7e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080008: 0x212d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008000c: 0xaaf0 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080010: 0x6821 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080014: 0x4af0 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080018: 0x365f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0008001c: 0x9d57 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080020: 0x72dc instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00080024: 0x8c85 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0000: 0x99b9 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0004: 0x74ee instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0008: 0x3537 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a000c: 0x1d2b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0010: 0xb5b8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0014: 0xc1be instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0018: 0xdfc4 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a001c: 0x1cb6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0020: 0x1407 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000a0024: 0xc4f3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0000: 0xde45 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0004: 0xf626 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0008: 0x4c68 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c000c: 0x33a2 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0010: 0xef3a instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0014: 0x0836 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0018: 0x7214 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c001c: 0x5533 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0020: 0xa840 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000c0024: 0x2aa6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0000: 0x1562 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0004: 0x65a1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0008: 0xeca3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e000c: 0x321f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0010: 0xad72 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0014: 0x9e35 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0018: 0x394e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e001c: 0x7b97 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0020: 0xf964 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x000e0024: 0xd303 instead
Old JFFS2 bitmask found at 0x000ede70
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100000: 0xf113 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100004: 0xfa2e instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100008: 0x0f9c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0010000c: 0x2c1f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100010: 0x7f18 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100014: 0x9042 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100018: 0xd439 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0010001c: 0xcbb2 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100020: 0x5719 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00100024: 0x2a7b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120000: 0x7fcf instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120004: 0xa97a instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120008: 0x3f60 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0012000c: 0x55f1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120010: 0x8f65 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120014: 0xf3d3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120018: 0x6068 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0012001c: 0x41c9 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120020: 0xbd74 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00120024: 0xc1b3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140000: 0x7ea1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140004: 0x3ad1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140008: 0x8706 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0014000c: 0x72eb instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140010: 0xba01 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140014: 0x5989 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140018: 0x4d09 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0014001c: 0xf834 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140020: 0xf253 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00140024: 0xe5ad instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160000: 0x6667 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160004: 0x158c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160008: 0xeaea instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016000c: 0xd7cf instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160010: 0xb3d9 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160014: 0xefdd instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160018: 0xfdf1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0016001c: 0xef8f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160020: 0x9998 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00160024: 0x9d73 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180000: 0x9f1c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180004: 0xb8c1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180008: 0xb769 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0018000c: 0x836b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180010: 0x93bb instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180014: 0x88d9 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180018: 0x2960 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0018001c: 0x51d6 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180020: 0x4007 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00180024: 0x9477 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0000: 0x2efa instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0004: 0x94f7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0008: 0xae7f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a000c: 0x72a8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0010: 0xeff7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0014: 0x0c74 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0018: 0x40c7 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a001c: 0x7a8c instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0020: 0x761f instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001a0024: 0x3c25 instead
Old JFFS2 bitmask found at 0x001b4fd8
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0000: 0xf5b9 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0004: 0x9b57 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0008: 0x9c97 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c000c: 0x7ea8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0010: 0xe08d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0014: 0xa2ef instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0018: 0x26fc instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c001c: 0xada8 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0020: 0xdb42 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001c0024: 0x8a62 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0000: 0xd9e4 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0004: 0x14dd instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0008: 0x0989 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e000c: 0x6152 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0010: 0xd4d3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0014: 0x2cce instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0018: 0x3268 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e001c: 0xda05 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0020: 0x8961 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x001e0024: 0x4fda instead
Old JFFS2 bitmask found at 0x001ec41c
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200000: 0x188d instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200004: 0x9aa1 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200008: 0xb002 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020000c: 0xd628 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200010: 0x1a53 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200014: 0xc7e0 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200018: 0x8d07 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0020001c: 0x7b27 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200020: 0x36c3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00200024: 0xbb41 instead
Old JFFS2 bitmask found at 0x002001f0
Old JFFS2 bitmask found at 0x00215b28
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220000: 0xe627 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220004: 0x44a3 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220008: 0xda1b instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0022000c: 0x6f28 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220010: 0xa799 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220014: 0x6121 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220018: 0xaddf instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0022001c: 0x84db instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220020: 0x9e67 instead
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00220024: 0xa743 instead
Old JFFS2 bitmask found at 0x00226778
Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
empty_blocks 202, bad_blocks 0, c->nr_blocks 220
VFS: Cannot open root device "mtd3" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00             384 mtdblock0 (driver?)
1f01             128 mtdblock1 (driver?)
1f02            4096 mtdblock2 (driver?)
1f03           28160 mtdblock3 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
Wenn ich stattdessen den Kernel von hier nutze, dann startet die Box, aber Netzwerk will dann nicht. Beschwert sich mit Socket Error:
viewtopic.php?t=16
Hat jemand eine Idee was da los ist?
Gruß McBane
Edit:
OK, das mit dem Socket Error beim Netzwerk mit dem älteren Kernel lag daran, dass ich die Teamübergreifenden Settings meines vorherigen Bluepeer Images geladen habe. Danach war "/etc/network/interfaces" nur noch ein Symlink zu "/var/etc/network/interfaces". Und das hat nicht existiert.
gandharva
Box: Tank
Re: Neo² - Ni-Image 3.3 startet nicht
Beitrag von gandharva »
Das Filesystem (jffs2) und die Partitionen + Partitionslayout sind lt. Log komplett vermurkst. BP nutzt afair irgendwelche Partitionslayout Eigenkreationen. Frag am besten dort nach wie du von deren Image auf ein Orginalimage kommst. Danach klappt es auch unser Image zu flashen.
Nazi lives don't matter.
mcbane
Hey erstmal danke für Antwort, aber wie erklärst du dir dann, dass der ältere Kernel funzt? Müsste doch die gleichen Fehler bringen....
EDIT:
Hier noch die Partitionen mit dem alten Kernel:
# df -h
Filesystem                Size      Used Available Use% Mounted on
rootfs                   27.5M     24.8M      2.7M  90% /
mtd3                     27.5M     24.8M      2.7M  90% /
devtmpfs                188.0M      4.0K    188.0M   0% /dev
tmp                     188.0M     36.0K    188.0M   0% /tmp
media                   188.0M         0    188.0M   0% /media
mnt                     188.0M         0    188.0M   0% /mnt
srv                     188.0M         0    188.0M   0% /srv
nfs                     188.0M      8.0K    188.0M   0% /var/lib/nfs
/dev/sda1                74.5G      9.3G     65.2G  13% /media/sda1
stefanx
Box: Alle CST SAT
Beitrag von stefanx »
.. wie machst du die Wiederbelebung?
Flashe über USB so ein Rettungs-Image,
dann flashe das NG2.7
und dann das NI3.3.
Hat bei mir immer so funktioniert.
mcbane
stefanx hat geschrieben: Fr 28. Apr 2017, 22:50 .. wie machst du die Wiederbelebung?
und dann das NI3.3.
Ja, über die Notfall-Recovery. Mit den Images aus oben genanntem Thread (aktuelles NI-Image+Kernel aus dem Thread):
viewtopic.php?t=16
Und so funktioniert es auch, aber wenn ich auch den aktuellen NI-Kernel nutze, dann funktioniert es nicht mehr.
stefanx
Box: Alle CST SAT
.. ich flashe immer ein gesamtes Image, ich bastle da nicht mit verschieden Kernel herum, es ist ja ohnehin immer der passende Kernel beim Image beinhaltet.
Wichtig nach der Wiederherstellung vor dem NI3.2 oder NI3.3 das NG2.7 vorher flashen.
mcbane
stefanx hat geschrieben: Sa 29. Apr 2017, 09:54 .. ich flashe immer ein gesamtes Image, ich bastle da nicht mit verschieden Kernel herum, es ist ja ohnehin immer der passende Kernel beim Image beinhaltet.
Joar, basteln würd ich auch nicht wenn's denn mit dem passenden Kernel funktionieren würde.
Kannst du mir denn den Grund nennen, warum ein vorheriges installieren von NG2.7 etwas verbessert oder ist das einfach nur Erfahrung?
Has thanked: 58 times
Been thanked: 98 times
Wie sieht's denn hier aus? Was macht die Box?
stefanx
Box: Alle CST SAT
mcbane hat geschrieben: Sa 29. Apr 2017, 10:24
.. genau, so ist meine Erfahrung und lässt sich immer wieder nachvollziehen.
Warum interessiert mich nicht, dann wenn es dann funktioniert ist es ohnehin Geschichte.
