DoYourData Uninstaller Pro 3.0 & MZ Cheque Print Simple 1.0.0
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — DoYourData Uninstaller Pro 3.0
DoYourData Uninstaller Pro offers all-in-one solution for Windows users to completely uninstall programs, Windows apps, and plug-ins from computer. It will uninstall selected programs and completely clean up all leftovers like program junk files, registry, logs, caches, etc.
NB: The registration data is in the Readme file.
Link
Giveaway of the day — MZ Cheque Print Simple 1.0.0
It’s an easy to use cheque printing software, which makes you able to define your cheque book and bank account, then simply print your cheques. Also the software allows you to record and manage your payees’ details. Users can easily scan their cheque leaves directly through the software and adjust the cheque parameters in the easiest way. It can be used with most normal office and home printers; it means you don’t need to buy a special printer to print your cheques.
Video tutorial
Link
mfG
Trapped
Kein Support per PN/Mail
