Eassos Recovery 4.2.1 & Solar System - Mars 3D
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Eassos Recovery 4.2.1
Eassos Recovery is professional data recovery software which provides complete solutions to recover lost data from any kind of storage devices with easy steps. It helps to recover data lost due to deletion, formatting, partition corrupt, RAW drive, etc. easily and safely.
Key features:
Clear and intuitive user interface directs you to recover lost partitions or files step by step.
Preview files before recovery. File preview feature is supported so that you can make sure whether data can be recovered correctly in advance.
It’s safe and risk-free. The recovery process is read-only and does not affect or overwrite original data.
It supports recovering data from FAT, NTFS and exFAT drives and partitions.
License info: 1-computer lifetime license
Link
Giveaway of the day — Solar System - Mars 3D
Feel as if you are looking out of the spacecraft window and seeing Mars illuminated by the sun. As the sun comes into view, you see the circular halos that come from the light reflecting off of an invisible glass that lies between you and space.
Subscribe to Youtube channel
Link
mfG
Trapped
Kein Support per PN/Mail
