Hetman Uneraser 3.9
trapped
Been thanked: 3 times
Hetman Uneraser 3.9
Beitrag von trapped »
Giveaway of the day — Hetman Uneraser 3.9
When your computer power suddenly goes off or you see a blue "screen of death", the first thought that comes to your mind is whether the document you were working on is still there. In case of a minor hardware error, your information will be just fine, but worst case scenarios also happen and that's when you should start being worried. A power failure, a virus attack or a critical error on your hard drive may knock you out of work for a long time and destroy your data.
Hetman Uneraser was created specifically for these needs. Offering a simple interface similar to that of Windows Explorer, it works with virtually any types of modern and legacy media, such as HDDs, photo cameras, USB devices, phone memory cards, cell phones, ZIPs and 3.5" disks. No matter which file system you use - FAT16, FAT32 or NTFS - Hetman Uneraser will be an equally efficient file recovery tool. The software scans the desired location and displays a searchable and sortable list of recoverable files that you can preview prior to starting the unerase process. Being able to preview a file is a guarantee of its 100% recoverability.
But even if the file can't be previewed, there is still a good chance that you will be able to recover lost data. Hetman Uneraser supports all file types and will be able to recover your files even after hard drive re-formatting.
You can learn more about the program from the video!
Please note, the program includes a half year license!
Link
mfG
Trapped
Kein Support per PN/Mail
