Update nur noch U-Boot
sysline
Beitrag von sysline »
ich habe auf meiner Zee das neue Image installiert.
Jetzt steht da nur noch U-Boot 2009.03-svn1773 und es tut sich nichts mehr.
Was kann ich tun?
Vielen Dank für Eure Hilfe.
Has thanked: 17 times
Been thanked: 12 times
Re: Update nur noch U-Boot
Serielles Log vom Bootvorgang posten.
sysline
ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
º U-Boot 2009.03-svn1773 (Nov 02 2010 - 15:25:47)     Coolstream HDx           º
ÌÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ͹
º Chipset information                                                          º
º Vendor: Conexant  Type: CX2450x (Nevis)  Revision: D0       Fuses: 7EFE6D24  º
º Option: 00410000  max. clock: 600 MHz    Core voltage: low                   º
º Clock information                                                            º
º MPG0: 594.000 MHz  MPG1: 594.000 MHz  HD  : 593.407 MHz  AUD : 491.520 MHz   º
º PLL0: 432.000 MHz  PLL1: 594.000 MHz  PLL2: 533.333 MHz                      º
º CPU : 594.000 MHz from PLL1                                                  º
º Memory configuration                                                         º
º Start    ³ End      ³ Type  ³ Description                                    º
ºÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĺ
º 00000000 ³ 0FFFFFFF ³ RAM   ³ System main memory bank #0                     º
º 10000000 ³ 17FFFFFF ³ RAM   ³ System main memory bank #1                     º
º F0000000 ³ F1FFFFFF ³ FLASH ³ Spansion S29GL256P (256 Mbit / 16M x 16)       º
º Serial number: 010-00006732 (0A-001A4C)                                      º
º *** Warning - bad CRC, using default environment ***                         º
º Network configuration                                                        º
º MAC: Conexant VMAC rev. 07       address: 00-C5-5C-00-1A-4C                  º
º PHY: IC Plus IP101               address: 09                                 º
Error: Bad gzipped data
Error: no valid bmp or bmp.gz image at f0060000
ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
Hit any key to stop autoboot:  0
   Image Name:   BPC Coolstream Kernel
   Data Size:    4136592 Bytes =  3.9 MB
   Load Address: 17048000
   Entry Point:  17048000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.26.8-nevis by BluePeerCrew (gcc version 4.3.2 (crosstool-NG-1.3.2) ) #1 Sun Feb 26 00:54:34 CET 2012
Machine: CoolStream HDx IRD
CPU0: D VIPT write-back cache
CPU0: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97536
Kernel command line: console=ttyRI0 mtdparts=cx2450xflash:384k(U-Boot)ro,128k(Splash),4096k(kernel),28160k(systemFS) root=mtd3 rootfstype=jffs2 rw mem=384M
PID hash table entries: 2048 (order: 11, 8192 bytes)
console [ttyRI0] enabled
Memory: 384MB = 384MB total
Memory: 383232KB available (3804K code, 349K data, 116K init)
net_namespace: 192 bytes
SCSI subsystem initialized
TCP reno registered
JFFS2 version 2.2. (SUMMARY)  © 2001-2006 Red Hat, Inc.
SGI XFS with security attributes, realtime, no debug enabled
msgmni has been set to 748
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
brd: module loaded
loop: module loaded
Inside emacdev_load function
Inside emacdev_init function
EMAC 0 Initialized
RealTek 8201 PHY eth0: Link down
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
CX2450x MTD driver v1.0 (Feb 26 2012, 00:49:47) (c) Coolstream International Ltd.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
4 cmdlinepart partitions found on MTD device cx2450xflash
Creating 4 MTD partitions on "cx2450xflash":
0x00000000-0x00060000 : "U-Boot"
0x00060000-0x00080000 : "Splash"
0x00080000-0x00480000 : "kernel"
0x00480000-0x02000000 : "systemFS"
cx2450x-ehci cx2450x-ehci.0: Conexant CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.0: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb usb1: Product: Conexant CX2450X EHCI USB-Controller
usb usb1: Manufacturer: Linux 2.6.26.8-nevis by BluePeerCrew ehci_hcd
cx2450x-ehci cx2450x-ehci.1: Conexant CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb usb2: Product: Conexant CX2450X EHCI USB-Controller
usb usb2: Manufacturer: Linux 2.6.26.8-nevis by BluePeerCrew ehci_hcd
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
Advanced Linux Sound Architecture Driver Version 1.0.16.
ALSA device list:
  No soundcards found.
TCP cubic registered
VFS: Mounted root (jffs2 filesystem).
Freeing init memory: 116K
FATAL: kKernel panic - not syncing: Attempted to kill init!
Kernel too old
gandharva
Box: Tank
Beitrag von gandharva »
Das ist nicht unser Image/Kernel.
Du musst Image UND Kernel via USB flashen!
Nazi lives don't matter.
sysline
das versuche ich die ganze zeit. aber es klappt leider nicht.
benötigt werden:
1x USB-Stick (FAT32 formatiert)
1. Auf diesen USB-Stick erzeuge ein Verzeichnis mit dem Namen "coolstream"
2. In dieses Verzeichnis coolstream kopiere die unten angehängten, entpackten Dateien als
kernel.img und system.img .
Beides ist als Download angehangen...
3. Schalte Gerät aus.
4. Stecke den USB-Stick in den USB-Anschluss auf der Frontseite des Gerätes.
5. Starte das Gerät.
6. Die Power-LED leuchten nun einmal "ein/ aus " und danach "ein", j etzt die Powertaste am
Gerät gedrückt halten.
7. Die Kontrollleuchte des USB-Sticks sollte nun blinken, dies signalisiert, das der Flashvorgang
gestart et wurde.
Die Powertaste nun loslassen.
8. Man benötigt nun ein wenig Geduld. Nach Beendigung des Vorganges wird die Box
selbstständig einen Neustart ausführen.
9. Die Box sollte nun wieder booten.
Auf diese Weise können ohne PC der Kernel und/ oder das System wiederhergestellt werden!
bekomme ich nicht hin.
was genau davon bekommst du denn nicht hin? ;)
ich vermute einfach mal, dass der USB-Stick nicht erkannt wird, die Coolie ist da recht wählerisch. Es funktionieren meist ziemlich alte und kleine Sticks, die neueren grossen mit zig Gigabyte eher weniger. Mancher musste schon mal den achten oder neunten Stick vom Nachbarn leihen, um es hinzubekommen...
Noch ein Tip: immer mitloggen und wenn du es selber nicht interpretieren kannst, dann hier posten.
gandharva
Box: Tank
Nimm bitte diese Anleitung: viewtopic.php?f=47&t=1923
Die andere ist denke ich wegen alten Kernel Files unbrauchbar. Ich werde gleich mal die HowTo Sektion aufräumen und entsprechende Threads entfernen.
sysline
ich habe jetzt vier USB Sticks probiert.
der kleinste ist 2 GB
keine Chance....
OK
Starting kernel ...
TCP reno registered
brd: module loaded
loop: module loaded
EMAC 0 Initialized
ALSA device list:
ernel too old
gandharva
Box: Tank
sysline hat geschrieben: ↑Mo 25. Sep 2017, 19:54 keine Chance....
Weil du nichts aus dem HowTo umsetzt. Die Box macht kein Update, sondern startet lediglich neu.
sysline
Au man Leute ich bin so dumm ....
Ich habe es nicht richtig gelesen ... ich habe den Powerknopf auf der Fernbedienung gedrückt und
nicht am Gerät .... ich könne mich Ohrfeigen.
Tut mir leid. Vielen Dank trotzdem für Eure Hilfe.
Eine Frage, meine Senderliste ist jetzt weg, kann ich die von der Trinity v2 Kronos nehmen und
auf die Zee spielen oder gibt das Probleme? ich meine per FTP von der Trinity runter auf die Zee.
die Senderlisten kannst du übernehmen.
