Abstract Curves 1.190 & Duplicate MP3 Finder Plus 7.0
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Abstract Curves 1.190
AbstractCurves is an image generator which allows you to create stunning wallpapers/backgrounds or posters in any resolution, or add effects or logos/watermarks to your photos. AbstractCurves includes a variety of built-in presets, and gives you the ability to create user presets. This program is available as a standalone application, and as a plug-in to the most popular graphic hosts, such as Adobe Photoshop, Adobe Photoshop Elements, Corel Paint Shop Pro, IrfanView, and others which support .8bf files.
Discover unique opportunities with the powerful features of AbstractCurves:
Unlimited number of effects;
More than 10 galleries with 130+ built-in presets;
Ability to create and save your own presets;
Ability to set any color of generated image and background;
30+ built-in color palettes with 7000+ colors;
Ability to create and save your own palettes;
Adding generated images to your photos;
Transparent background option for creating logos, icons, avatars, etc.
16-bit image support.
Link
Giveaway of the day — Duplicate MP3 Finder Plus 7.0
Just a faster duplicate music finder with 100% accurate results you will love!
Comparing Audio Contents, 100% Accurate Result;
High-speed Comparison Algorithm;
Smart Selection: Automatically Checks the Unwanted Audio;
Supports Almost All Popular Audio Formats;
Very Easy to Use, Only Need 1 Click to Get Result;
Flexible Sources: Drive(s), Folder(s), Files and Type(s);
Reusable Result: Save/Load the Duplicate Audio Listing;
Helpful Options: Smart Selection, Sub Folders, Hidden Files, Excluding Paths;
Marks the Adjacent Duplicate Audio Groups by Different Colors.
Please note: Single License (1 PC) (Lifetime License WITHOUT Upgrades) is included in this version. Click here to get a VERY BIG discount price for other licenses with Lifetime Upgrades on the promotion day!
Link
mfG
Trapped
Kein Support per PN/Mail
