NI-Image 3.50 (Changelog) - Beta
Gesperrt
Has thanked: 74 times
Been thanked: 127 times
:N:eues :I:mage online
:I:mage:
92b8bc1 - bump image version to 3.50
1b3f782 - ni.mk: create changelogs in staging dir
d001ee9 - channellists: update matze settings
83de4f0 - bump gstreamer + deps
0362352 - neutrino.mk: make usage of gstreamer configurable
1c996df - neutrino.mk: force gstreamer in libstb-hal
84d9dab - gnutls 3.6.1
e6708da - ni.mk: add changelog target; create cleaned changelogs in build_tmp/
:N:eutrino:
17b84a0 - bump neutrino version to 3.50
be61130 - neutrino.cpp: fix small merge error
a5448c8 - movieplayer: re-enable youtube playback
5c735a6 - movieplayer: try to fix lua-playlist playback; ...
7df613a - user-menu: avoid empty headers in user-menu
cc645d2 - filebrowser: add size() and getFilter() members
8115cf2 - locale: split fileplay hints into audio and video
9fb2036 - user-menu: add audio fileplay item
67ea34c - luainstance: update keyname table
764b255 - neutrino: add more RC_playpause handling
d4a9c29 - neutrino: add RC_playpause handling; change some key defaults for ARM_HARDWARE
b162d95 - rcinput: add RC_playpause key
c91cb3a Icons: use fixed language and youtube icon
d2c2ec0 Icons: use default hint from own icon set
b9f0bf8 Icons: add missing hint icons and fix some files with format errors
e6da7fd audiomute.cpp: fix clear screen after audiomute
7cfb6bb - acinclude: configure for generic hardware by default
dac03ad - streaminfo: add fallback to delivery system detection
1eb0d00 - settings_manager: fix issue tag on reset settings item
7be696c - icons: install missing lcd4linux hint icon
8137a4c - icons: add default hint icon
736f778 - icons: add some more missing hint icons for settings manager
9088eb5 - icons: add material style hint_saveas icon
f38e03a icons: fix assignment of settings, network and mainmenu icons
6c781b0 CSettingsManager: add cancel buttons to backup/save config messages
52c279f CSettingsManager: use neutrino internal debug output,
aa1c166 icons: add missing picon vor save as
fc2629e CPictureViewer: add current image into debug line
73fa25f CSettingsManager: add hintbox while execute backup_sh
864907a - settings_manager: remember last used directory
8f080ff - settings_manager: add TARGET_PREFIX define to backup/restore calls
b0c4a28 - acinclude: fix TARGET_PREFIX define for native target
533302b - settings_manager: remove NI code around backup_sh
3912ff4 - imageinfo_ni: use package version as fallback for image version
3a2f289 data: update crypt icons
39fb9f4 CComponentsFooter: fix force re init of button container
8b1b722 CTestMenu: add example for variable caption inside message buttons
057cee2 src/gui/screensetup.cpp reset channellist modules
9389e78 - infoviewer_bb: small renamings to get more logic in function names
198c8f4 fix icon alignment
8e97f98 - locale: small changes in infobar ca system locales
cda63a9 - zapit/channel: fix issue tag from 4bacd77f8bcd61c21b99a1cfc52fce6a8d46c5fd
ef1a760 - infoviewer_bb: add gradient to ca-bar; ...
96cb7f8 - infoviewer_bb: always show hdd fill level for a more uniform view; ...
7457354 - icons: add tandberg crypt icons
78a7c34 update cryptsystems
4bacd77 CZapitChannel: add issue tag
89019ac - channellist: fix segfault while virtual zapping and bouquets are empty
8aa7451 - rcinput: fix compiler warnings about unused variables
7b55de6 CMenuWidget: ensure use of unified data type const char*
2a2d51d CComponentsInfoBox: add possibility for scalable picons
1c44ca2 adding adapter to debug output
c1bca3f tryfix scan frontend selection
1d0545e CServiceManager: use value 0 as init value for feparams.plp_id
d50c5bf femanager.h increase max adapters to 4
c6c5153 - webradio_usr.xml: add link to stompfm.de
175e452 - locale: clarify timerlist.ask_to_delete locale
libstb-hal:
647a4dc armbox eplayer: reactivate audio, subtitle and chapters
07a2b21 armbox eplayer: add chapter.c
16d1d14 armbox eplayer: add chapters
07a7366 armbox eplayer: align to last commits
03c9c49 armbox eplayer: use other tracklist
12daaec armbox eplayer: add metadata
fcb622f armbox eplayer: small fix TTX
30fd93d libeplayer3-arm: fix playback (thx DboxOldie)
d598e42 fix video policy
c5f2ab5 fix close files
31daba0 - generic-pc/audio: fix segfault in getAudioInfo() function
d2b5eae add libeplayer3-arm test
5387d98 acinclude: some more minor format changes
03865d3 libeplayer3: code format
5c8d315 - Makefile: disable libstb_hal_test stuff; this completes 188f10dd8644c30f64b04c99447c165193fb9790
7d84a3e generic gestreamer align to armbox
398ed0c gstreamer: increase seek accuracy
Gesperrt
