Notebook 2.0 & Amigdala
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Notebook 2.0
Notebook is a well designed tool to write, edit and store all your documents for your private life or your daily work. No more searching for the notes and documents you need, just press a (user defineable) hotkey to show the program window and read or write your text.
Store an unlimited number of text documents in a single file (Microsoft SQL Server Compact 4.0 database);
The database can be encrypted with a password, using a safe 128-bit RSA encryption;
Documents are organised with a folder structure, so you can easily separate large document collections;
Powerful text editor with all common formatting options, like different fonts and font styles, search and replace;
Insert pictures into your documents (in-text or free floating, resizable);
Import and export to and from RTF, HTML or TXT format;
Configurable hotkey to show/ hide the program window, making it always accessible in an instant;
Two additional modules: "Passwords" (store all your login data in one place, including a sophisticated random password generator) and "Contacts" (a handy contact manager).
Link
Game Giveaway of the day — Amigdala
Gherman, a middle-aged man who has abandoned all to find what lies behind the "Philadelphia experiment". 11 years after the experiment, Gherman found a document that marked the coordinates of the project's military establishment. Certainly, he didn't expect to find so much...
Link
mfG
Trapped
Kein Support per PN/Mail
