BootRacer Premium 7.30
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — BootRacer Premium 7.30
BootRacer is a light-weight, easy to use and convenient tool for monitoring the Windows PC boot time and controlling over startup programs. The main approach of BootRacer is an ability to exclude a user password timeout time from the calculated total.
How does BootRacer save my time and my life?
BootRacer calculates the clear Windows boot-up time (without password timeout).
It monitors your PC's boot time and notifies you about any speed degradation.
BootRacer measures Total Time used by startup programs at every boot.
You will know which programs slow down Windows boot-up.
You can easily disable slow down programs from Windows startup.
NB: Lifetime license with no updates and tech support, no commercial usage.
Link
mfG
Trapped
Kein Support per PN/Mail
