Focus Projects 3 Pro (Win&Mac)
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Focus Projects 3 Pro (Win&Mac)
With FOCUS projects 3 professional, you can use an exposure series to create an image with fantastic depth and where even the smallest object is in crisp focus from front-to-back. The smaller the object being photographed and the lesser the distance, the narrower the area of focus is. Particularly with full-frame cameras, this field of focus can amount to less than a millimeter. The solution: FOCUS projects 3 professional!
Link
mfG
Trapped
Kein Support per PN/Mail
