Easy Photo Unblur 2.0
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Easy Photo Unblur 2.0
Easy Photo Unblur improves the quality of camera shots by removing excessive noise and sharpening the blurred objects.
Making photos in motion or unfavorable light conditions often results in blurred or noisy shots. With Easy Photo Unblur pictures become crystal clear thanks to smart digital optimization. The program algorithms unblur photos by detecting misfocused objects and intelligently cleaning the noise.
The program offers a range of unblur pics modes with adjustable parameters – smoothing radios, detalization, noise pre- and post processing. Depending on the noise intensity, you are free to use different unblur image modes to fix the handshake, misfocuse and motion blur. This unblur picture app supports batch image optimization that is much faster than unblur photos one by one. Just drag and drop the image folder to the app and start processing.
There are many ways how to unblur a picture, and the most of them require professional skills in graphics editing. Easy Photo Unblur fits everyone regardless of skills in photography and design. The program helps to unblur a picture using artificial intelligence mechanisms. It is much more efficient than flat sharpening used in the most of alternative solutions. A user can preview the result and compare it with original photo before saving changes.
Purchase an Unlimited personal license (with support and updates) at 70% discount!
Link
mfG
Trapped
Kein Support per PN/Mail
