Cables.xml WTC SN
Has thanked: 171 times
Cables.xml WTC SN
zwar gehört die WTC Schwerin ja seit einiger Zeit zu PYUR aber dessen Netze sind ja alles andere als einheitlich.
Hier mal eine aktualisierte Transponderliste des Anbieters. (3 TPs wurden abgeschaltet)
	<cable name="WTC SN" satfeed="true" flags="9">
		<transponder frequency="306000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="113000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="121000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="130000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="314000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="322000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="0" modulation="3"/>
		<transponder frequency="338000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="346000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="354000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="362000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="370000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="378000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="386000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="394000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="402000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="410000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="418000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="426000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="434000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="442000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="450000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="458000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="474000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="490000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="498000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="506000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="514000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="522000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="530000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="538000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="546000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="554000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="562000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="570000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="586000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="786000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="794000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="810000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
	</cable>
Re: Cables.xml WTC SN
Da heute die Analogen Sender abgeschaltet wurden wurde das gesammte Netz umgestrickt. Hier die aktuelle cables.xml für das WTC SN Netz:
		<transponder frequency="466000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="262000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="270000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="278000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="294000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="306000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="314000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="322000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="330000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="482000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="578000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="594000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
		<transponder frequency="602000" symbol_rate="6900000" fec_inner="0" modulation="5"/>
	</cable>
mit QAM 64 gibt es keine TP mehr, selbst die ÖR SD Sender werden jetzt mit QAM 256 eingespeist.
Zurück zu „Senderlisten“
