NI-Image 3.1 Betatest - Changelog
Gesperrt
gandharva
Box: Tank
Beitrag von gandharva »
Neue Images für alle Boxen Online (04.05.2016)
- aktueller Neutrino GIT Stand
NG -> NI transition (work in progress):
- de-NG ecm-info; move to osd_setup
- de-NG iconsets; move to osd_setup
- de-NG hint icons
- de-NG our TouchFileNotifier
- de-NG lcd4linux code
- de-NG osd scart fix; move to osd_setup
- FIM: NG->NI
- FIM: fix NI Picture
- locales: small cleanups
- images: proper view in onlineupdate
- dpf-ax: bump to rev54
- lcd4linx: add ttf and scale patches by TangoCash
- lcd4linx: de-NG lcd4linux patches
- remove lcd4linux patches
- build lcd4linux from upstream
- lcd4linux: align init script
Nazi lives don't matter.
gandharva
Box: Tank
Re: NI-Image 3.1 Betatest - Changelog
Neue Images für alle Boxen Online (Hotfix 04.05.2016)
- osd_setup: fix crash; item will be deleted by menue automatically
gandharva
Box: Tank
Neue Images für alle Boxen Online!
- osd_setup: fix initial icon assignment for our iconsets
- icons: use FTA-icons to preview our iconsets
- de-NG plugins hide menu
- de-NG plugin names and descriptions
- sort locals
- locale: small cleanup
- de-NG: start/stop options
- de-NG some more locales
- de-NG MN_WIDGET_IDs
- de-NG hdd power; move to hdd_menu
- de-NG some menu stuff
- ni-menu: small improvements
- menue.cpp: allow linefeeds in menu-hint
- locales: remove obsolete vinfo locales
- ng_menu_netfs. -> netfs_setup.
- de-NG ni_menu; ng_menu. -> ni_menu.
- de-NG netfs locale
- netfs: rename CNETFSSmallMenu to CNETFSSsetup
- add/update licence informations
- netfs_setup: remove unused CNETFSUmountGui class
- de-NG many comments; please use //NI in future
- more de-NG helpers code
- more de-NG netfs; ng_netfs* -> netfs*
- add ni-migration.sh script to align neutrino.conf
- yWeb: upgrade prototype.js to v1.7.3
- add our yWeb-extension to neutrino source
- use neutrino makefiles to do yWeb changes
- add DarkOrange theme to neutrino sources
- add our infoicons to neutrino sources
- do only install language files that we really need
- add screensaver files to neutrino source
- add webtv_usr.xml sample to neutrino sources
- data/Makefile.am: align to cst
- rework some of our code and add comments; align to cst
- minor lcd4linux changes
- xupnpd: switch to new git repo and adapt all old patches (needs testing!)
- bump confuse to v3.0 and add libite 1.6.0 static target for recent inadyn versions (needs testing!)
Die Umstellung von NG auf NI sollte nun erledigt sein. Sofern es keine grösseren Probleme gibt, ist geplant die NI Neutrino Sourcen in den nächsten Tagen auf bitbucket zu releasen.
Wir werden dann hier im Forum einen neuen Bereich schaffen in dem man sich bei Interesse mit der Neutrino Entwicklung beschäftigen kann.
NI \o/
gandharva
Box: Tank
First build from new public repo!
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... ommits/all)
- src/gui/Makefile.am: fix git describe
- locale: fix wrong entry
- minor alignments to cst-git; no binary changes
- icons: use NI icons
- data/fonts/Makefile.am: re-use md_khmurabi_10.ttf as neutrino.ttf
- remove garbage
- lcd4l: several changes
- movieplayer: make pretty_name public
- xupnpd: use old ui-template as default
gandharva
Box: Tank
- Neues Logo toggo plus, Änderung bei rtl living, diverse Symlinks für Unitymedia
- Logos TNT Comedy (HD) und SR Fernsehen nochmal angepasst
- neue Logos. You RTLII webtv und RTL Living
- Revert "- xupnpd: use old ui-template as default"
gandharva
Box: Tank
- pr-auto-timer: v0.38; fix new movies at Sky Cinema
- fix ni-neutrino-hd branch
- ffmpeg: re-add old mkv & mp4 seek "fix"
- inadyn: temporary workaround to make latest HEAD usable
- new Logo for DorcelTV and DorcelTV HD
Bitte unbedingt den ffmpeg MKV-Fix testen, ob damit alles OK ist!
gandharva
Box: Tank
- switch to new buildserver
- inadyn: switch back to official repo
- Revert "Revert "- xupnpd: use old ui-template as default""
Wichtig!
Dies ist der erste (noch manuell erstellte) Build unseres neuen Buildservers!
Wir werden in Zukunft unsere Imageentwicklung auf Kontinuierliche Integration und Rolling Releases basierend auf automatisierten wöchentlichen Builds umstellen. Das heisst es wird keine Release Images geben! Die jeweils letzte Beta bzw. der letzte Build am Server ist Stand der Dinge. Weitere Infos zu den Änderungen gibt es in den nächsten Tagen. Derzeit ist geplant das 1x wöchentlich automatisch Images gebaut werden und bei Bedarf (neue Commits im Neutrino Repo oder Tests) manuell ein Build angestossen wird. 8-)
Has thanked: 64 times
Been thanked: 106 times
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... e9d5290e61)
- DPF zeigt nun während der Movieplayerwiedergabe wieder das Play-Symbol
- Nach einem Werksreset ist nun Deutsch als Haupttonspur eingestellt.
- xupnpd: Fix WebIf (nochmalig); Danke, dryeye.
gandharva
Box: Tank
- libfuse 2.9.7
- libcurl 7.49.1
- libpng 1.6.23
- libjpeg-turbo 1.5.0
- openssl 1.0.2h
- libgd2 2.2.1
- openvpn 2.3.11
- openssh 7.2p2
- iperf 3.1.3
- inadyn: 2.0-rc1
- libite: 1.8.0
- coreutils: 8.25
- smartmontools 6.5
- nano 2.6.0
- ntfs-3g: 2016.2.22
gandharva
Box: Tank
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... 8f4fa8394e)
- freetype 2.6.3
- neuer default font + neues default fontscaling (105%) im Image
- neue Kanallisten von matze, Luj++ und PathAuf
gandharva
Box: Tank
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... cf049eb087)
- use default values for freetype fontcaches (needs testing!)
- epgview: align imdb <-> tmdb view
- channellist: set CI channel inactive if recording with CI
- update inadyn.conf examples and add "secure-ssl=false" to avoid update problems due to cert errors
- kernel hd2: add some upstream patches (up to 3.10.102) that might affect us. (perf, ext4, fuse, nfs, and so on...)
- libdvbsi++: add improved version of previous patch. this should fix memleaks
Prüft bitte eure inadyn Configs auf die neue Syntax! Die neuen Kernelpatches sind auf der Kronos Plattform noch ungetestet. Bitte um Rückmeldung ob alles OK ist damit!
gandharva
Box: Tank
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... 4a978f26e9)
- system/httptool: make timeouts flexible
- imdb.cpp: cleanup before download and reduce timeouts
- Ask user for storing overlapping CI timer from epg
- add/use //NI tags instead of /*NI*/; just cosmetic changes
- imdb: fix metascore output
- imdb: show english title in txt-field to get more space for data
- imdb: fix poster position
- imdb: better description for title tag
- epgview/imdb: rename bool 'imdb_activ' to 'imdb_active'
- imdb: fix deletion of posterfile
- imdb: add getPoster() function
- icons: add imdb icon
- imdb: change filenames
- imdb: show original title after rating stuff
- imdb: show metascore after rating votes
- neutrino: add tmdb_api_key
- epgview: rework imdb view; allow tmdb view
- allow tmdb in moviebrowser/movieplayer
- epgview: re-fix description of adzap-button
- epgview: laying tmbd to RC_0 to get back historically control
- epgview: add own locale for tmdb-info
- neutrino: force tmdb_api_key if previos entry is default
- New Logo N24Doku and some symlink changes.
- Logo for new channel Sky Arts HD (sat) and zee.one (cabel) and some new symlinks.
- tectime on astra is back, logo too. And some more symlink changes.
Neue Neutrino-Updates für alle Boxen Online!
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... 878ad66edd)
- moviebrowser: remove osd rests behind info window
- epgview: fix segfault, when imdb cover is saved in moviebrowser
- add submenu to configure and control online services like youtube, shoutcast and tmdb
- disable youtube, when youtube_dev_id is empty
- disable tmdb, when tmdb_api_key is empty
- disable shoutcast, when shoutcast_dev_id is empty
- epgview: add imdb button to footer
- imdb: add plot to imdb output
- epgview: remove imdb/tmdb mixing
Unter Einstellungen -> Erweiterte Einstellungen -> Onlinedienste ist ein neues Menü zu finden, in dem die Zugänge zu Onlinedienste wie TMDb, SHOUTcast und YouTube verwaltet werden können.
Viel Spaß und einen schönen Sonntag. ;)
- aktueller Neutrino GIT Stand (https://bitbucket.org/neutrino-images/n ... 1a17c60a6a)
- CImageInfoNI: Fix display imagesize for root1 sysfs on HD2 hardware
- CImageInfoNI::paint_NET_Info: Fix max_bit for hd2 hardware
- themes: add three new material themes
- themes: fix infobar_casystem_alpha in DarkOrange theme
- colors: smoother interplay; use 1px frames
- icons: transparent background for clock_face icon
- analogclock: Save background for using transparent clock images
Am Farbzusammenspiel hab ich bissel was geändert, um eine dezentere Ansicht zu erhalten. Falls euch irgendwas negativ auffällt, gebt bitte Bescheid.
Auch sind drei neue Themes in Material-Farben hinzugekommen. Die sehen, wie ich finde, besonders schick aus, wenn man sämtliche 3D-Effekte in der GUI abschaltet. Wen nur die hässlichen Icons nicht wären ... ^^
Ich wünsche mir einen kompletten Satz moderne flache Icons im Material-Design. Weihnachten steht ja vor der Tür. ;)
Von fred gab es ungefähr vierhundertfünfundachzigtausend neue Sky-Logos. :D
In der Infobar kann nun für die analoge Uhr ein transparenter Bild für das Ziffernblatt verwendet werden. Danke an micha_bbg.
Viel Spaß mit den Images. :NI: \o/
Gesperrt
