HitFactor 7.1.0
trapped
Been thanked: 3 times
HitFactor 7.1.0
Beitrag von trapped »
Giveaway of the day — HitFactor 7.1.0
HitFactor is the music-making software with everything you need to create the basis for your next song. It is step sequencer, VST-host and music notation software. HitFactor is easy to get started with and it is a very useful application for song writers and music makers. Create, compose, edit and finish your music with HitFactor.
The program can automatically generate instrument melody, drum beats, chord progression, and bass line with different music instruments. HitFactor also contains a virtual finger picker a MIDI music notation module and a built-in text editor which can be employed to create lyrics for the newly written song. HitFactor contains everything you need to create songs, record and play audio files and add lyrics to Wave, OggVorbis, Wma, Mp3 and MIDI files.
Supported audio file formats: Wave audio files, OggVorbis audio files and MIDI files
Features:
Quick compose music.
Create song with a mouse click.
Export the project file to MIDI file.
View the MIDI file music notation.
Create instrument melody.
Create finger style melody using the virtual finger picker.
Create chord progression.
Create bass line.
Load drum beats from the Drum beats library.
Create drum beats.
Write your own song including song lyrics.
Play and record song using midi keyboard.
Playback any supported audio files.
Load Windows 32 bit, VST 2 and VST 3 audio effect plugins.
Improve the sound quality with the 10 bands equalizer.
Record Wave and OggVorbis audio files.
Record vocals, using microphone.
Record streamed audio data.
Write and edit song lyrics in the song text editor.
Add lyrics to wave, OggVorbis, wma, mp3 and MIDI files.
Play and sing your own song and record it to your hard disc.
Save your work as a project file and open it whenever you like.
Link
mfG
Trapped
Kein Support per PN/Mail
