Genie Timeline Home 10 & VideoProc 3.2 (Win&Mac)
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Genie Timeline Home 10
Since 2001, Genie9 has worked on developing backup and security software for home and business PC users. The Genie9 products designed for home users are extremely simple and easy to use. According to Genie9, Genie Timeline Home is more than just a data-storage application, it is a feature-packed backup suite that manages to keep files safe without any fuss.
From start to finish, Genie Timeline Home 10 is effective and easy to use. It guides users through the backup process and restores files in an intuitive manner. As an added bonus, this software does all of these things without draining system resources.
Link
Giveaway of the day — VideoProc 3.2 (Win&Mac)
VideoProc is by far the most powerful software of Digiarty that integrates video editing, downloading, recording and DVD video audio conversion. By taking full use of unique level-3 GPU acceleration, it is skilled at fleetly processing 4K/8K, large-sized and high-speed videos from cameras, phones, Drones, etc. Meanwhile, it can keep highest possible video audio quality with smallest possible output size.
All-purpose video processing functions:
Editing: cut, split, crop, merge, resize, reframe (30/60/120/240fps), add effect/subtitle/watermark, make Gif, etc.
Fixing: stabilize shaky videos, denoise, defisheye, rotate/mirror, 3D to 2D, slow down or speed up footages, etc.
Adjusting: compress video size, customize bit rate, resolution, GOP, encoding mode, force A/V sync and more.
More practical features:
Convert any old/new DVDs, videos, audios to any video/audio formats. Downscale 4K to 1080/720p, vice versa.
Download video, audio playlist and channel from 1000+ UGC websites. Support batch downloading.
Capture computer/iOS screen, record video with webcam and remove/change background from a webcam.
Bonus: Digiarty also provides you a unique chance to gain Lifetime Full License at 60% off discount.
Link
mfG
Trapped
Kein Support per PN/Mail
