Secret Messages Pro 2.0.0 & AudioWeb 1.0
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Secret Messages Pro 2.0.0
Secret Messager Pro is a software which is designed to encrypt your messages before you send them. If you would like to send message online, then you should not worry on how you can prevent unauthorized access to the messages. There are some people out there who are eager to hack your messaging account and read the information you are trying to send. The program generates encryption images which hide your message before you can send. The send will have to receive the key generated upon message encryption before he or she can read your message.
Secret Messages
The feature allows you to encrypt messages before you can send them. There are different types of messages you send online using your internet enabled computer but you would like them to stay secure, the tool allows you to generate encrypted messages before you can send them.
Secret Files
It allows you to encrypt files with AES256 tool before you can send them. Before the files have been encrypted, you need to generate a secret key which can be used to decrypt them. The tool works in a straight forward way allowing you encrypt and decrypt files.
Secret Images
It allows you to hide messages in an image with a key. Before anybody can open the files or read the messages, he or she must use the secret key you will send to him.
Link
Giveaway of the day — AudioWeb 1.0
NB: The software requires Windows 8.1 or Windows 10.
AudioWeb requires the Microsoft .NET Framework version 4.6.1 to run. This should normally already be present in your system
AudioWeb also requires the DotNet Core 2.0.9 Windows Hosting Bundle to run
AudioWeb creates a personal website on your computer allowing you to play your mp3 audio files through any web browser! Extremely simple setup; IIS not required.
AudioWeb plays audio files sequentially, ideal for audio books or podcasts.
You can easily browse, play and bookmark audio files using any modern web browser on any iPad, iPhone, Android phone or tablet, or Windows/Mac desktop.
Create any number of separate users, each with his/her own bookmarks and settings.
AudioWeb never loses your place in a book, even if you log out.
You can use AudioWeb only within your local router if desired, or open a router port to play your audio from anywhere on the internet.
AudioWeb is a natural complement to PodSilo by MollieSoft, which collects and maintains podcasts for you.
Link
mfG
Trapped
Kein Support per PN/Mail
