TwinkiePaste 2.15 & My Lovely 2.0.0
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — TwinkiePaste 2.15
TwinkiePaste is the utility to quickly typing commonly used text, dates, greetings, standard responses, Internet URLs, logins and passwords, code templates. TwinkiePaste helps to quickly type text in almost any application, thus saving a lot of time and saving you from routine. How TwinkiePaste works? Press a hotkey in any application. TwinkiePaste displays a menu with text templates to be inserted near with cursor. Select the menu command. Done! Text is inserted.
Get TwinkiePaste now at 50% discount! The program provides free updates until May, 26.
Link
Giveaway of the day — My Lovely 2.0.0
My Lovely is a slideshow that displays pictures in a user-selected area of the screen and is always shown on top of the other windows. It allows you to glance at your pictures while you work with other software and encourages quick, momentary breaks helping you feel refreshed while regaining your focus and inspiration.
The slides can be fully opaque or semi-transparent allowing you to see through them, and when you place the mouse over the slide, it fades away and reappears after the mouse is removed, which also allows you to work with the windows under the slide. My Lovely displays your own photos or from beautiful internet galleries. It has a native multiscreen viewer capable of applying extreme zoom on photos, allowing you to view even the tiniest details. My Lovely can also play videos and display notes. The slideshow changes slides after a preselected period of time has elapsed or a user command.
Users with the best improvement ideas will get: 1 first prize: Full commercial license for Act On File, multi-user 5 PCs; 3 second prizes: Full commercial license for Act On File, single-user 2 PCs; 10 third prizes: Home license for Act On File, for 2 PCs!
Link
mfG
Trapped
Kein Support per PN/Mail
