Hi,I have 2 errors in Zee I used to update on line,installed satellites.xml and good, but latest updates
I have my channel list, example: (ESPN)installs well,but after a minute,change to unknown(1432)????
and the other mistake that you don't Zee have HDMI? only have rgb output and ypbpr input ???
Zee HDMI???
lilo74
- Box: Mutant HD51.Coolstream Trinity sat
Zee HDMI???
Mutant HD51,2Coolstream Trinity Sat, Vu+solo seV2,edision argus pingulux plus,Azbox Me,golden media one,2 coolstream zee DVB-S2 and DVB-C
- Has thanked: 19 times
- Been thanked: 39 times
Re: Zee HDMI???
Bye,
what do you mean exactly? Because the Zee surely does have HDMI-Output, so you say, in your box it is broken (no picture on Tv) ?and the other mistake that you don't Zee have HDMI? only have rgb output and ypbpr input ???
Check, if you have Menu->Setup->Blue->Channellist->"Transponder background update" is active (which would explain this strange behavior) or not (then there should be no change in the settings "by automatic").example: (ESPN)installs well,but after a minute,change to unknown(1432)????
Bye,
lilo74
Re: Zee HDMI???
Hi Friend,yes I have Video in Tv but sound No, TV 4k ,to get sound,I need to connect optical output,
Thanks
Thanks
