Folder Marker Home 4.3
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Folder Marker Home 4.3
This handy utility, normally $24.95, lets you assign colors and icons to Windows folders for easy at-a-glance identification.
In the ordinary world, we’re using markers, highlighting important documents or laying them out in folders of different colors. This allows us to be organized and quickly find the information we need. Why don’t we bring the same approach to our computer files world?
This is exactly what today’s deal software is doing. Folder Marker enables you to mark folder icons to indicate a priority level (high, low, normal), level of project completeness (done, half-done, planned), work status (approved, rejected, pending), and type of information stored within (work, important, temp and private files).
Simply right-click on any folder and select the icon or color to be used from the newly added menu option. The perfect download if you need a little extra boost getting your files in order. Try it now!
SPECIAL OFFER FOR GAOTD:
Get advanced Pro version of Folder Marker, FileMarker.NET or any additional icon set with up to 50% discount. This offer is valid TODAY only. So you have the ability to test Giveaway edition and upgrade it to the most functional paid version with a huge discount. This gives you the right to use Folder Marker in your office, Click here to see what you can get with 50%-off today
[urlhttps://de.giveawayoftheday.com/folder-marker-home-4-3-2/]Link[/url]
mfG
Trapped
Kein Support per PN/Mail
