PDF Eraser Pro 1.9.4.4 & MSTech Search in Contents 1.8.6 & Royal Defense Ancient Menace
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — PDF Eraser Pro 1.9.4.4
PDF Eraser is a Windows PDF content eraser software tool that deletes and removes text, images, logos and all unnecessary objects from your PDF documents. You are allowed to use this application to delete original content and text from a PDF file, and then add any text and images you want. Besides that, this PDF Eraser utility has a built-in PDF Page Cutting tool, which enables you to delete unwanted PDF pages. Considering lots of scanned PDF documents, PDF Eraser also added the PDF Rotating function rotates PDF pages properly with 2 clicks.
Link
Giveaway of the day — MSTech Search in Contents 1.8.6
Surely it happens, that you need to find and read a document quickly, whether an MS document file, RTF, txt, pdf or even a PHP file.
It would be always time consuming and frustrating process, you have to open all documents and check their contents one by one to find your desired document. It's even worse when you are faced with a mass of unorganized documents and files.
MSTech Search in contents is a very handy and useful software which helps you to find your desired documents in the easiest and quickest way possible. You just need to define your search path/multiple paths, type your desired keyword or phrase and click on the search button, then you will have quick access to all documents containing your keyword.
You won't need to open any other software to see the files' contents, you can easily see the whole document preview, beside the search results' column.
SPECIAL OFFER FOR GOTD:
MSTech Search in Contents Pro v2 1PC ($45) with 55% OFF => $20
Link
Game Giveaway of the day — Royal Defense Ancient Menace
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
Become a part of an exciting story based on the dwarven kingdom's eternal struggle against the Ancient Menace, who only wants to crush the dwarves and claim their territory!
To defeat the monstrous hordes, you must construct defensive towers and units and learn to wield powerful spells. All your towers and units have specific stats: Damage, Fire rate, Damage radius, Damage type, as well as various other features, such as enemy slowdown and Damage Over Time.
Each level also brings new units and structures to help you fight your enemies. You’ll never be lacking for new and exciting ways of decimating those ancient threats! Build towers, earn money, collect crystals and upgrade your spells – the enemy shall not pass!
Link
mfG
Trapped
Kein Support per PN/Mail
