ApowerUnlock 1.0.1.6 & Soft Organizer Pro 7.46 & Deep Ocean Rush
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — ApowerUnlock 1.0.1.6
ApowerUnlock is a smart and powerful tool specially designed to unlock iPhone/iPad/iPod Touch screen and Apple ID. It has an intuitive interface and is easy to use. Using ApowerUnlock, you can unlock iOS screen without passcode no matter how it has been locked. Aside from unlocking 4- or 6-digit passcode on iOS devices, it also allows you to unlock fingerprint passcode or Touch ID, Face ID, and iCloud password.
When it comes to Apple ID, you are also allowed to unlock Apple ID without a passcode using ApowerUnlock. With its advanced features, you can remove an existing Apple ID on your iOS iPhone/iPad/iPod Touch if you are using an iDevice running an iOS 11.4 previous version. Therefore, you can change to a different Apple ID or create a new one, and take advantage of iCloud services and enjoy all Apple ID features.
Key Features:
*Unlock iOS screen without passcode.
*Unlock Apple ID or iCloud account on iOS devices running iOS 11.4 previous versions.
*Reset iPhone/iPad/iPod Touch easily.
*Fix disabled iPhone/iPad/iPod Touch without iTunes or iCloud.
*Bypass all types of passcodes on iOS devices, including 4-digit or 6-digit passcode, Apple ID, Touch ID, and Face ID.
*High compatibility with iOS devices, including iPhone, iPad, iPod Touch, etc.
*Intuitive interface comes with instructions on it.
*Support multiple languages.
Steps to unlock your iPhone/iPad/iPod Touch screen
• Connect your iOS device to PC using a lightning cable.
• Select “Unlock Screen” on the main interface.
• Choose or download a firmware once your iOS device is recognized.
• Unpack the firmware.
• Start unlocking your iOS screen.
Steps to unlock your Apple ID or iCloud account
• Connect your iOS device to PC with a lightning cable.
• Select “Unlock Apple ID” on the main interface.
• On your iOS device, go to “Settings” > “General” > “Reset”, select “Reset All Settings” and confirm.
• Start unlocking Apple ID.
NB: The license can be used for 1 time unlocking within 1 year once fully activated.
Link
Giveaway of the day — Soft Organizer Pro 7.46
Soft Organizer ist eine ausgezeichnete und sehr einfach zu bedienende Software, um Programme vollständig unter Microsoft Windows zu installieren/deinstallieren. Programme können mit Tracking installiert werden, d.h. das Tool zeichnet alle Orte im System auf, an denen das installierte Programm Spuren hinterlässt. In Zukunft erlauben euch diese Informationen, das Programm vollständig entfernen, einschließlich aller Reste, die nach der regulären Deinstallation über die Systemsteuerung im System verbleiben.
Soft Organizer ist außerdem mit einem Suchmechanismus ausgestattet, um Spuren von Programmen zu finden, die nicht automatisch nachverfolgt wurden. Dies bedeutet, dass fast jedes Programm, das jemals installiert wurde, jetzt vollständig gelöscht werden kann, wodurch die Unordnung und Verstopfung von Windows mit unnötigen Dateien verhindert wird.
Bei Programmen, die ihr lieber installieren möchtet, kann Soft Organizer nach verfügbaren neuen Versionen suchen und euch über ein spezielles Symbol in der Anwendungsliste darüber informieren. Durch die rechtzeitige Aktualisierung der installierten Programme könnt ihr viele Probleme vermeiden, da neue Versionen in der Regel sowohl neue Funktionen als auch wichtige Fehlerbehebungen enthalten.
Das integrierte Bewertungssystem bietet eine Möglichkeit, nicht benötigte und minderwertige Produkte zu finden und loszuwerden.
Link
Game Giveaway of the day — Deep Ocean Rush
Deep Ocean Rush is an unusual Defender in which you have to fight off the waves of sea monsters with the help of the dwarf brothers and their tower, improving your equipment along the way.
The gameplay consists of shooting hordes of enemies from a cannon, finding the desired projectile trajectory and calculating the landing point and in which understanding of timings can be useful.
The game will take you to the village called Pago, which was attacked by the monsters of the underwater world. Your task is to protect civilians and save the wealth of the village from unexpected guests.
The main characters - brothers Tom and Jerry - warriors who embarked on the path of war.
Complete levels, earn gold and upgrade your skills.
A variety of ammunition will help to defeat enemies.Let there be a war!
Over 100 different levels
7 different types of improvements and upgrades
10 Super Bosses
15 different types of monsters
Link
mfG
Trapped
Kein Support per PN/Mail
