MSTech Easy Desktop Organizer 1.9.9 & Windows Product Key Finder Personal 2019
trapped
Beitrag von trapped »
Giveaway of the day — MSTech Easy Desktop Organizer 1.9.9
NB: The software requires .NET Framework 4.8 or higher
Most of us keep our frequently used files, folders, and applications' shortcuts for quicker access.
Most of the time, we will end up with a messy, confusing desktop.
MSTech EDO, helps you to have access to your files, folders, and shortcuts, while you have a clean and organized desktop.
You can create an unlimited number of windows on your desktop, show or hide them as you need. Easily keep unlimited files, folders, and shortcuts categorized by your style just by drag and drop them over the windows.
Each window comes with a built-in search tool, which makes you able to find your desired file or folder easier and faster.
Furthermore, you can manage your desktop wallpapers/backgrounds directly through the software. Also, you can enjoy downloading free high quality (HD) desktop wallpapers from the MSTech website.
The Giveaway Promotion Details:
- No Free Update
- No Free Upgrade
- No Free Support
- No Commercial Use
SPECIAL OFFER FOR GOTDD:
Buy MSTech Easy Desktop Organizer v1.9.9 + FREE UPGRADE to v2.0 + 73% OFF ($3.99). One Day Only.
Link
Giveaway of the day — Windows Product Key Finder Personal 2019
+ Stellt Lizenz- / CD-Schlüssel aller Windows XP / 2003/2008/2012 / Vista / 7/8/10 wieder her
+ Stellt Seriennummern von über 500 gängigen Programmen wie Office, SQL Server, Adobe, VMWare usw. wieder her.
+ Stellt Schlüssel von beliebten Spielen wie FIFA, NFS, Age of Empires, Quake usw. wieder her.
+ Sichert wiederhergestellte Lizenzschlüssel in einer HTML-Datei
+ Installer für einfache Installation und Deinstallation
+ Professioneller technischer Support & kostenlose Updates (6 Monate)
+ Unterstützte Betriebssysteme: Windows 10/8/7 / Vista / XP, Windows Server 2016/2012/2011/2008/2003 (32-Bit und 64-Bit)
Bitte beachtet:
1) MS Office 2016/2019 speichert nur die letzten fünf Ziffern des Lizenzschlüssels
2) Die Wiederherstellung von Lizenzschlüsseln für Software und Spiele von Drittanbietern hängt von der Version ab
Lizenzgültigkeit: Jahreslizenz
Link
mfG
Trapped
Kein Support per PN/Mail
