Recovery HD51
EnoSat
Box: MIO4K+ & HD51 & Solo4K
Recovery HD51
Beitrag von EnoSat »
any chance recovery HD51 ?
Actual status:
not display, only on RS232 write
CPU 01
BCM74390012
PRID07251112
v1.7
RR:00000003
BFW
SEC
seclib-1.5
BBL v1.0.1
AVS init...
spare0/rmon_hz=017e7878
spare1/rmon_vt=017e7878
AVS init OK
AVS load:select_image: addr_offset: 00051000 part_offset: 00000000 bootStatus: 2a002b00
AVS load_code offset =00051000
AVS: OTP Decrypt 0x00000000, OTP Verify AVS 0x00000000
LOADED
single board
select_image: addr_offset: 00055000 part_offset: 00000000 bootStatus: 3d2b2500
MemsysFW: OTP Decrypt 0x00000000, OTP Secure Boot 0x00000000
SHMOO 01020000 BLD:9695 HW:hpf0_b1p6 V:1.2.0.0
MCB: FIX
AVS start:status=000000ff
STB: Current voltage=000003cd(973)
 temperature=0000b2c4(45764)
 PV=0000037a(890)
 MV=000003ce(974)
AVS FW rev=30333078 [0.3.0.x]
OK
DDR0: *@ ffe0ba98 <= ffe0ba98 MEMSYS-0 @ f1100000 OK
DDR1: -
Sdram Scramble OTP = 0x00000001
Sdram Scramble OK
select_image: addr_offset: 00020000 part_offset: 00000000 bootStatus: 1b25252b
BFW load mode OTP = 0x0000000f
bfw_hash_locked = 0x00000000
BFW key3 OK, CPU 01
BCM74390012
PRID07251112
v1.7
RR:00000403
BSP Debug Info:
0x4204010f
0x00000122
0x00000000
0x0000002a
0x00000030
0x00000000
0x00000100
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
BFW
SEC
seclib-1.5
BBL v1.0.1
AVS init...
AVS init OK
AVS load:*** BCHP_BSP_GLB_CONTROL_GLB_DWNLD_ERR is set.
select_image: addr_offset: 00051000 part_offset: 00000000 bootStatus: aa252b2b
LOADED
single board
select_image: addr_offset: 00055000 part_offset: 00000000 bootStatus: bd2b252b
MCB: FIX
STB: Current voltage=000003d2(978)
 PV=0000037d(893)
 MV=000003d2(978)
OK
DDR1: -
Sdram Scramble OK
BFW:0000002f
FATAL ERROR: Boot 2nd image failed
bootloader not work fine :(
USB ignored
with power button
without power button
Gibertini OP100L /85E-53W/
Has thanked: 17 times
Been thanked: 17 times
Re: Recovery HD51
An der Console STRG C drücken, dann bleibt der bei boot stehen
An der Console kann man dann Befehle absetzen
dann mal help eingeben und sich die möglichen Befehle anschauen
War Multiboot im Flash oder nur ein Image ?
Was haste denn gemacht das der nicht mehr durchbootet und kein USB mehr kennt? Bootloader geflasht/gelöscht ?
Wenn der Bootloader kaputt ist, wird man dir nicht helfen können.
Evtl. Hersteller /Distributor könnten dir helfen, der https://efe-multimedia.de ist eigentlich sehr hilfsbereit ?
Keine Garantie mehr auf der Box ?
Thomas
Re: Recovery HD51
Beitrag von Thomas »
EnoSat
Re: Recovery HD51
CTRL+C ignored
USB ignored
Multiboot
none Garantie
