Aeroadmin Pro 4.1 & SlideShow 8 Premium
Keine Stimmen
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Aeroadmin Pro 4.1
Aeroadmin - easy remote desktop software! It requires no installation and configuration. It is small in size and can be started up in less than a minute. It is perfect when you need to connect to a remote PC as soon as possible for either a full on remote control session or a simple file transfer.
Key Features:
Works without installation and configuration;
Connects computers behind NAT;
Branding + access rights preconfiguration;
Built-in ticket sending system for helpdesk;
Small in size, portable;
Secure File Transfer;
Unattended access;
Remote user logoff, reboot (including in safe mode);
Total AES + RSA encryption;
3-factor authentication;
Unlimited concurrent sessions.
Please note: the program includes the one year license!
Link
Giveaway of the day — SlideShow 8 Premium
With SlideShow 8 Premium you can quickly and inexpensively create an appealing photo/video show. Captivate your audience with exciting video shows that are unlike others, neither stale nor boring. In a hurry? Use the integrated SlideShow-Master, a guided Wizard that helps you every step of the way: select images and video clips, add background music, choose a pre-defined style template. DONE.
You can learn more from the video!
Link
mfG
Trapped
Kein Support per PN/Mail
