FILEminimizer PDF 7.0 & Apowersoft PDF Converter 2.2.2.8 (Win&Mac) & The Bizarre Creations of Keith the Magnificent
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — FILEminimizer PDF 7.0
FILEminimizer PDF compresses PDF files and documents and reduces PDF file sizes by 40-75% using balesio's native format optimization technology for PDF file compression. The software optimizes PDF structures and compresses pictures, graphics and objects within a PDF file while preserving the original file format and quality. Compressed PDF files are much smaller, consume less storage space and are ideal for sharing and sending via email. Recipients don't need the software to edit or view the compressed PDF files. Mailboxes, servers, file storage and networks are relieved and loading time is accelerated.
- PDF file compression by 40-75% - a 25MB PDF file is compressed to 5MB in size
- Supports all PDF file types - compress scanned PDF files, "born-digital" PDF documents such as converted Microsoft Office files and other PDF files
- Optimizes pictures, graphics, objects and internal PDF structure to reduce the size of PDF files
- Keeps the original PDF file format - simply edit, view and change it without the need to unzip
- Integrated search function finds all PDF files on the PC for compression
- "Drag & Drop" files directly into FILEminimizer to compress several files at once (batch processing)
- Add-ins for Microsoft Outlook, Lotus Notes and Windows Explorer
Link
Giveaway of the day — Apowersoft PDF Converter 2.2.2.8 (Win&Mac)
Apowersoft PDF Converter is a useful PDF converter. It is designed for help people work more efficiently. It can convert PDF to other formats and vice versa, also it works for merging PDF and more. With one account, you can convert PDF files on Windows PC, Mac, Android mobile and your iOS devices.
Features of Apowersoft PDF Converter (for Windows only)
- Split PDF
Using this program, you can choose the pages you need and put them into a new PDF document or divide a PDF into numerous PDFs.
- Extract images from PDF
Only need the pictures inside the PDF? You can use this feature to extract the images from a document.
- Other features
Apart from the aforementioned features, this program can also helps you to compress, protect and unlock PDF, and even copy text from scanned PDF.
Three Steps to Use this PDF converter:
1. Open the application and go to the certain function you need.
2. Tap to choose the file(s) you need and hit the convert button to start conversion.
3. Once done, you can go to the output path to get the documents.
Link
Game Giveaway of the day — The Bizarre Creations of Keith the Magnificent
A point and click puzzle adventure about the mad wizard Keith, and his quest to find friends. Keith is a very lonely man, and no one comes to his parties - so he decides to rob an entire graveyard to create zombie cyborg friends to come to his parties. Join him in robbing graves, cutting up corpses, creating steam-punk cyborgs and hosting parties - and then dealing with the consequences when he upsets everyone.
You will use his skills as an accomplished wizard, scientist and engineer to solve his problems - from making a heart beat, creating a death machine or just mixing a delicious drink, combining multiple items at the same kind to make all sorts of bizarre creations.
Explore his life through 10 levels, get him out from the depths of depression, help him find friends, make friends, lose friends, and make more - some in more traditional manners than others.
Link
mfG
Trapped
Kein Support per PN/Mail
