Auslogics Disk Defrag Pro 9.4.0
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — Auslogics Disk Defrag Pro 9.4.0
Recommended by experts as one of the fastest and most efficient defraggers, this tool defragments and rearranges files on your hard drive to restore efficiency.
Ultra-Fast Engine. One of the fastest defraggers in the world, Disk Defrag often takes less than 10 minutes to defragment an average-size hard drive.
Consolidates Free Space. Merges scattered pieces of free space into a contiguous block, preventing fragmentation of newly created files.
Lists Fragmented Files. You can see which files are the most fragmented, as well as the location of each fragment on the disk map.
Defrags Single File or Folder. Can save you time by defragmenting only the files or folders you want instead of the entire hard drive.
Works the Way You Want. You can use the default settings for convenient one-click defrags or customize program operation and appearance to fit your needs.
Industry-Acknowledged Quality. The exclusive Auslogics technology is proven safe and effective in multiple tests, used by PC manufacturers and recommended by experts.
Link
mfG
Trapped
Kein Support per PN/Mail
