MSTech Search in Contents Pro 2.0.0 & Cubis Creatures
trapped
Been thanked: 3 times
Beitrag von trapped »
Giveaway of the day — MSTech Search in Contents Pro 2.0.0
Surely it happens, that you need to find and read a document quickly, whether an MS document file, RTF, txt, pdf or even a PHP file.
It would be always time consuming and frustrating process, you have to open all documents and check their contents one by one to find your desired document. It's even worse when you are faced with a mass of unorganized documents and files.
MSTech Search in contents is a very handy and useful software which helps you to find your desired documents in the easiest and quickest way possible. You just need to define your search path/multiple paths, type your desired keyword or phrase and click on the search button, then you will have quick access to all documents containing your keyword.
You won't need to open any other software to see the files' contents, you can easily see the whole document preview, beside the search results' column.
SPECIAL OFFER FOR GOTD:
Buy MSTech Search in Contents Pro v2.0 + FREE UPGRADE to v3.0 - 75% OFF ($11.25). One Day Only.
The Giveaway Promotion Details:
- No Free Update
- No Free Upgrade
- No Free Support
- No Commercial Use
Link
Game Giveaway of the day — Cubis Creatures
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
Cubis is a match-3 game unlike any other with unique 3D gameplay. Action truly comes at you from all sides - cubes can fall from above, shoot in from the side, and even push other cubes out of the way. Easy to learn yet difficult to master, only the best and most dedicated players will earn the coveted ‘Perfect’ rating on every level. Are you up to the challenge?
Link
mfG
Trapped
Kein Support per PN/Mail
