MiniTool ShadowMaker Pro 3.2 & MSTech PDF Split Merge 1.0.0
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — MiniTool ShadowMaker Pro 3.2
MiniTool ShadowMaker is an all-in-one data protection and disaster recovery solution for PCs. It can back up your Windows Operating System, important files/folders, selected partitions, and even the whole disk. With a copy of backup, you are able to restore data once a disaster occurs, like system crash, hard drive failure, and more.
MiniTool ShadowMaker also lets you create a bootable media to restore system to a normal state when a computer fails to boot. With MiniTool Media Builder and MiniTool PXE Boot Tool, hard drive maintaining is not a difficult issue.
Link
Giveaway of the day — MSTech PDF Split Merge 1.0.0
MSTech PDF Split Merge gives you a preview of the pages you want to split or merge. You can select pages or simply split a file into specific pages or number of files. It also gives you the option to merge your pdf files with varius handy options.
The Giveaway Promotion Details:
- No Free Update
- No Free Upgrade
- No Free Support
- No Commercial Use
SPECIAL OFFER FOR GOTD:
Buy MSTech PDF Split Merge v1.0 + FREE UPGRADE to v2.0 - 60% OFF ($5.99). One Day Only.
OTHER OFFERS FOR GOTD USERS ONLY TODAY:
1. MSTech Golden Pack Lifetime Upgrade $550.00 $29.99 %94
2. MSTech Silver Pack Lifetime Update $550.00 $24.99 %95
3. MSTech Bronze Pack 1 Year License $200.00 $14.99 %92
4. Folder Icon Pro $55.00 $9.99 %81
5. Swift Gadget $55.00 $9.99 %81
6. Search in Contents Pro $45.00 $9.99 %77
7. Search in Contents Basic $30.00 $5.99 %80
8. Image Resize Basic Basic $20.00 $5.99 %70
9. Easy Desktop Organizer Basic $15.00 $5.99 %60
10. Check Writer Pro $210.00 $14.99 %92
11. Check Writer Basic $210.00 $9.99 %92
Link
mfG
Trapped
Kein Support per PN/Mail
