FileMarker.NET Pro 2.1 & AceThinker Video Master 4.8.2 (Win&Mac) & Alien's Armageddon
trapped
Beitrag von trapped »
Giveaway of the day — FileMarker.NET Pro 2.1
Organize your files with color- and image- labeling. FileMarker.NET allows you to mark individual files by priority (high, normal, low), project completeness (done, half-done, planned), project status (approved, rejected, pending) and type of information (work, important, temp, private). Or paint them with normal, dark, or light colors.
File marking can be used in a great number of situations. For instance, you can use FileMarket.NET to mark files that must be completed by the end of the week with a yellow color, as well as to set priorities and completion values. This way, you will always have a clear picture of the amount of work lying ahead and your progress on particular tasks.
Using the program is extremely easy - just 2 mouse clicks are needed! The customizable context menu is opened by right-clicking the necessary file. Custom file icons are applied immediately after the user selects the corresponding command.
Key features:
Can customize one file or multiple files together;
Allows you to color-mark a file, or add a label to it, or use a combination of color and a label;
Has 52 build-in image-markers;
Can colorize a file to normal, dark and light states. 33 color variations for professional file management are available;
Allows you to load your own icons, downloaded from the Internet;
Works with PDF and DOCX files.
Link
Giveaway of the day — AceThinker Video Master 4.8.2 (Win&Mac)
Video Master is a universal video and audio converter with basic editing features. It is capable of converting videos into various multimedia formats for different devices easily and fast. The tool also includes the Split Screen and MV Maker features with lots of available presets to make a presentation neat and more appealing. The screen recorder feature is great for capturing desktop activities and converting them for later viewing.
Convert your media files to portable or high-quality video/audio formats.
Edit your video by using trim, watermark, annotation, visual effects and more.
Record screen along with audio, annotation and task manager.
Premium features of video recorder, MV maker and more.
Link
Game Giveaway of the day — Alien's Armageddon
People are playing with the gods and their actions interfere with the natural development of the universe. Extraterrestrial civilizations gave them a lot of chances to come to their senses, but man fancied himself the crown of the universe, there is no more time and the space Federation had nothing left to do but simply wipe humanity off the face of the Earth.
Alien's armageddon is a side-scrolling shooter with a side view, where the player acts as the destroyer of humanity. The player controls an alien ship, which is technologically, many times higher than the level of earthlings. People throw all their strength to stop the harvest.
Dozens of ground vehicles, aircraft, anti-aircraft guns will resist the player.But will they be able to stop the invasion?
Passing levels and destroying enemy equipment, the player earns points, for them you can pump your ship by buying more technological weapons that will decide the fate of one of the parties.
Link
mfG
Trapped
Kein Support per PN/Mail
