NIUBI Partition Editor Professional 7.3.6
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — NIUBI Partition Editor Professional 7.3.6
NIUBI Partition Editor Professional Edition is a reliable disk partition management software for Windows 10/8/7/Vista/XP (32 & 64 bit).
It helps shrink, extend, move and merge partitions without data loss to optimize disk space. Fix file system error and defrag partition to improve computer performance. Copy disk partition to migrate Operating System and data. Convert disk and partition type without losing data. Create, delete, format, hide, active, wipe partition, scan bad sectors, etc.
Better than other partition manager software, NIUBI Partition Editor has advanced technologies such as:
• Virtual Mode - the operations you do will be listed as pending for preview and real disk partitions won't be modified until click Apply to confirm.
• 1 Second Rollback - automatically reverts computer to original status in a flash if any known software or hardware issue occur, if it happens nothing will be changed.
• Cancel at well - cancel unwanted but ongoing operations without losing data.
• Unique file-moving algorithm - 30% to 300% faster than other tools.
Video Guide
Link
mfG
Trapped
Kein Support per PN/Mail
