HEIC to JPG Converter 9.3 & Apocalypse City Arena
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — HEIC to JPG Converter 9.3
HEIC to JPG converter easily converts .heic or .heif photos from your iPhone or iPad into any popular graphic format (JPG, PNG, it also supports RAW images (CRW, CR2, NEF, PEF, RAF, RAW, DNG, MNG, etc) High Efficiency Image File Format (HEIC) is used by default on new photos on iOS 10 - 12, and it's there to save your storage space. It's new so it has to face some incompatibilities. HEIC format is still not supported by the popular graphic editors and viewers and Apple hasn't offered a solution yet. HEIC to JPG converter not only converts .heic photos from your iOS device to other formats but also introduces a simple drag&drop user interface and delivers fast and smooth image conversion. It can help you quickly finish batch image resizing for sharing and publishing your photos. Optionally, you can add text, logos and image watermarks to protect the converted pictures, as well as change canvas size, flip images, mirror, rotate them in the process, plus adjust level and color. For more advanced users GUI and command line are available. The files can also be renamed in batch mode. The program smoothly integrates with Windows 7, 8 and 10 Explorer.
Purchase an Unlimited personal license (with support and updates) at 70% discount!
Link
Game Giveaway of the day — Apocalypse City Arena
After the big cataclysms, many people escaped to live in the catacombs. But all valuable resources remained on the surface. A lot of people set out on their own to gather what they need, and it's every man for himself. Try to survive and return with the loot.
Control keys:
F - Pick up weapons, ammo
1,2,3 ... Change weapons
WASD - Character movement
SPACEBAR - Jump
SHIFT - Sprint
Esc - Exit to the menu
LKM - Shoot
Link
mfG
Trapped
Kein Support per PN/Mail
