Opera Mail to Outlook Transfer 5.4.1.0 & TwistedBrush Tree Studio 2.17 & Help
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Opera Mail to Outlook Transfer 5.4.1.0
Opera Mail to Outlook Transfer automatically converts unlimited-size mailboxes of the discontinued Opera Mail client to Microsoft Outlook. The process is automatic, meaning the program detects the location of the *.mbs mailbox files, then asks for your confirmation and with zero intervention from you transfers the complete contents of these mailboxes to either Outlook or to a dedicated PST file.
Opera Mail to Outlook Transfer offers extra-high conversion accuracy thanks to automated processing based on special algorithms. These algorithms take into account many factors that possibly can influence the overall quality. Specifically: the tool correctly deals with encodings, precisely transfers Opera folder structure in Outlook, keeps track of fonts and styles in messages and so on.
Moreover, the program even recovers data from damaged Opera Mail files. And on top of that is a cherry: the program is automatic as in “does everything for you”: supports all Outlook versions and Opera mailbox formats, deals with huge mailboxes, and even splits a single resulting PST file into several smaller ones.
Link
Giveaway of the day — TwistedBrush Tree Studio 2.17
Tree Studio is a product born from TwistedBrush Pro Studio but with a focus on 2D tree creation with a simpler, streamlined interface. Internally the same great TwistedBrush brush engine is used, but with a single focus of making it easy to create trees of specific types. Tree Studio has pairs of brushes for each tree type. One for the frame and one for the leaves. The frame is algorithmically generated so it will be different each time. This allows you to create an endless variety of each tree type.
Link
Game Giveaway of the day — Help
Your daughter was gone at a research of the abandoned bunker. Having gone to find her, you meet the horrors living in these walls, solve puzzles, discover what has happened in this place and to find the daughter. Everything that you have, is a lamp which charge constantly decreases also the radio.
Features
Support a lamp charge by means of batteries
Use the radio for the solution of puzzles and to discover location of enemies
Read notes to learn about what has happened
Link
mfG
Trapped
Kein Support per PN/Mail
