Image to Video GUI 2.25 & Cubozoid
trapped
Been thanked: 2 times
Beitrag von trapped »
Giveaway of the day — Image to Video GUI 2.25
Image to Video GUI tool can convert images to videos with 2D and 3D slide transition. The program supports PNG, JPG and BMP images. You can set effect duration and type as well as slide duration. It is easy performing and allows you inserting an external audio track into your video.
The business license allows using the tool at the company level for commercial purposes.
Link
Game Giveaway of the day — Cubozoid
Exclusive offer from Giveaway of the Day and MyPlayCity! No third-party advertising and browser add-ons!
Cubozoid is fast and furious fun! Your job: keep a parade of colored cubes from filling up the game board. As the blocks progress through an elaborate maze, you must fire your own arsenal of colored cubes at the procession in an attempt to create groups of three or more blocks of the same color. When you make a match, the cluster explodes! Special cubes are on hand to help you win. The Chameleon Cube changes its color to that of the block it hits, while the Lightning Bolt destroys an entire row or column of cubes. Just watch out for the trick cube that makes the blocks move faster! Use the pickups well and you'll visit exotic locations around the world, including China, India and the Wild West.
Link
mfG
Trapped
Kein Support per PN/Mail
